01-06-2015, 11:45 AM | #1 |
Drives: '99 Mitsubishi Mirage de coupe Join Date: Sep 2014
Best kind of automatic transmission for high horsepower (1800+HP)
Hey guys, as the name says I was wondering what the best kind of automatic transmission for ridiculously high horsepower numbers, like around 1800-2000+ horse. I'm going to be a building my Camaro that's gonna have that much power and the transmission is screwing me over because I can't find one. Thnx in advance for the information and plz be civil in your posts.
01-06-2015, 11:46 AM | #2 |
Guess I should also mention, I'm specifically looking for a 6-speed auto if possible but will do with 5 or more gears.
01-06-2015, 01:32 PM | #3 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
TH400
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
01-06-2015, 02:59 PM | #4 |
Could be my inexperience & lack of fully understanding of how autos work but is there a six speed variant of the th400 other than its grandkid the 6l80e which I was was already looking at but the highest rated one I found was 1,200 horse from PATC. Will google for information tho.
01-06-2015, 03:47 PM | #5 |
Drives: 2009 ZR1 Join Date: May 2010
You can make a TH400 a six speed by adding a gear vendors overdrive.
https://www.gearvendors.com/hrgm3s.html http://www.jakesperformance.com/TH400.html They offer transmissions for 1500+hp and it mentions 2000hp+ combos as well. Out of curiosity, what are you doing with the car you want 1800hp+ and a six speed auto, besides going REALLY fast? |
01-06-2015, 03:53 PM | #6 |
Its gonna be a combo DD & drag car
01-06-2015, 05:13 PM | #7 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
TH400 is basically your only choice for that power.
01-06-2015, 10:42 PM | #8 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
Yup, that or a glide. Your at a minimum 1000hp off of what any 6 speed can handle, don't care who builds it.
Bryan
01-07-2015, 12:46 AM | #9 |
Yeah TH400 with about $5k or more in just parts and if you have to have a 6 speed throw a GV on the rear like Blake said.
01-07-2015, 08:48 AM | #10 |
Well if it makes a difference, I'll be adding a trans cooler from Mishimoto to the setup, will that help a six speed or will it make no diff?
01-07-2015, 09:27 AM | #11 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Trans cooler don't necessarily increase holding power. It's the decrease in trans temps that help it live and live longer.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
01-07-2015, 09:50 AM | #12 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
What are you doing for rear? That's alot of power.
01-07-2015, 09:53 AM | #13 |
Drives: ZL1/TBSS/COPO Join Date: Apr 2012
If your talking 1800rwhp you better look at a Glide. Power Glide or a Turbo Glide.
.....2012/14 COPO #33....427, 1.31 60' ....9.39@143......
01-07-2015, 11:54 AM | #14 | |
Motor mounts: http://www.bmrsuspension.com/?page=p...284&superpro=0 Motor mount pucks: http://www.bmrsuspension.com/?page=p...293&superpro=0 Bushings: http://www.bmrsuspension.com/?page=p...464&superpro=0 Sub-frame connectors: http://granatellimotorsports.com/pro...e-2384-28.html |
