dave@hennessey
Old 01-01-2015, 02:33 PM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Parking Manual transmission?
So while I'm waiting to go pick up my ZL1 tomorrow I decided to re-read the 13' Camaro manual to see if I can pick up any ZL1 tid bits....
Section 9-24 says to put the manual transmission in reverse and then shut the car off?
I've always left my manual cars in 1st gear when parking.
Any reason or logic to what the car manual recommends?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 01-01-2015, 02:36 PM   #2
punkindave
The Great Punkin
punkindave's Avatar
Drives: 2013 2SS M6
Reverse gear is lower than first..
In past cars I've always used first because reverse always seemed to not engage quite right and would occasionally pop out. (Older cars) Also never used parking brake after I had one freeze in the winter. (again, old car) LOL
Who opened up a fresh box of idiots without finishing the old box, now they're everywhere!!
Tesla > Edison
punkindave is offline   Reply With Quote
Old 01-01-2015, 02:37 PM   #3
Bizaro
Drives: 2015 Redhot 1LE
When parked at home I leave it in neutral since where i park its flat, other than that I park in either reverse or 1st depending on angle of slope.
Bizaro is offline   Reply With Quote
Old 01-01-2015, 02:39 PM   #4
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
If I'm parking front end up hill, I put it in first. If I'm parked front end down slope, I put it in reverse.
Enjoy the ZL1 !!!
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 01-01-2015, 02:48 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Enjoy the ZL1 !!!
Ok, thx makes sense. Thx
Mods:
Old 01-01-2015, 03:17 PM   #6
banter
banter's Avatar
Drives: 2016 Camaro 2SS M6 Black
Enjoy the ZL1 !!!
This, if I'm on flat ground, I park in neutral. Always using the parking brake of course.
banter is offline   Reply With Quote
Old 01-01-2015, 05:42 PM   #7
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
I put it in first or reverse, whichever will do the least damage if I accidentally let the clutch out in gear at startup...
not that I've ever done that...
Flashpoint135 is offline   Reply With Quote
Old 01-01-2015, 06:15 PM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
I have no idea what Chevy's logic is unless it's tied to the logic of an old anti-theft technique requiring you to put the transmission in reverse gear where movement of a back-drive linkage off the reverse lever on the transmission would then let you remove the key. Friend of mine with a '71-ish big-block Camaro had to deal with this.
Personally, I always leave any MT car in either reverse or 1st, and my choice of which depends mainly on which direction would cause the least damage should the car actually be able to start without the clutch pedal fully depressed. I've had cars that never had a clutch starter interlock to begin with (I am that old), a car with it that physically broke its little switch, and a car whose clutch interlock was such a PITA that inside two weeks I had intentionally and completely disabled it.
Leaving a MT car in neutral is a lot like leaving an AT car in "N" instead of "P" - you've just thrown away the more reliable means of holding the car still for no good reason, and are now relying on the P-brake being in proper adjustment. Cables stretch, fray/unwind, freeze up in winter . . . just saying.
Norm
Old 01-01-2015, 06:42 PM   #9
Baldwin feeder
Drives: 1986 Chevy C-10 and 2013 BRM 1SS
I have always parked manual transmiasion cars in first gear including my current Camaro. I wonder if it would be worth trying to retrain myself after all these years.
Baldwin feeder is offline   Reply With Quote
Old 01-01-2015, 06:59 PM   #10
1SSFever
Drives: 2012 1SS
Oh no not this again.
Reverse or first it doesn't matter, 30 years never had a mishap. Never has my car rolled into another while parked.
Then there's the camp that wants to leave their car in neutral and put total trust in the parking brake.... that's risky.
Rowing through the gears of an SS Camaro always makes for a better day.
1SSFever is offline   Reply With Quote
Old 01-01-2015, 07:13 PM   #11
Turbosaurus
Turbosaurus's Avatar
Drives: '14 Camaro 2SS/1LE
Depends on how I parked...
Head in = reverse
Backed in = first
Past:
'69 Chevelle SS396
'79 Camaro 400SBC/TH400
Present:
'14 Camaro 2SS/1LE
'03 Avalanche (tow car for...)
Twin-turbo SBC Super Comp Dragster
Future:
FFR 33 Hot Rod w/ SBC
RCR GT-40 w/ LS7
Turbosaurus is offline   Reply With Quote
Old 01-01-2015, 07:42 PM   #12
Unrulie
Unrulie's Avatar
Drives: 2011 Camaro SS Cyber Grey
Neutral and parking brake every time every vehicle. I've had over a dozen manual trans vehicles for 30 years including my 2013 Kenworth. That's 80,000 lbs on the parking brake.
Unrulie is offline   Reply With Quote
Old 01-01-2015, 07:50 PM   #13
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
I read in this forum that it also kept the battery from draining when parked in reverse. Don't know if true, but plenty of stories on C5 about older Corvettes and dead batteries due to the issue. Since it's in the owner's manual I've been doing it on both Camaro M6 cars since 2009. Common sense, too, always use e-brake.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 01-01-2015, 09:11 PM   #14
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
Usually in 1st with parking brake on in all situations. With my old 73 Z/28 Muncie M22 it had to be in reverse. Lift up and to the left to remove the key.
Quicksilver-SS is offline   Reply With Quote
