Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 10-07-2014, 12:27 PM   #1
JGiovando
Drives: 2018 1SS 1LE HBM
Vitesse throttle controller
I've seen a few discussions on this but want to ask those that have one to chime in with their thoughts having used it. Thanks in advance.
JGiovando is offline   Reply With Quote
Old 10-07-2014, 12:34 PM   #2
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
Buy it. Enjoy it. That is all.
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 10-07-2014, 12:54 PM   #3
moE_09
Drives: 2014 v6
Best bang for the buck by far. Woke up the inner beast
moE_09 is offline   Reply With Quote
Old 10-07-2014, 01:44 PM   #4
pinoyscorpion951
pinoyscorpion951's Avatar
Drives: 2016 Bright Yellow 2SS A8
Out of all the mods that I've done: ported throttle body, CAI intake with racing scoop, Solo high flow cats with resonated xpipe, MRT V2, and an IPF tune, the throttle controller had the most noticeable improvement by a long shot. 10 minutes to install. The ability to change the settings on the fly. Best 180 dollars that I've spent. I don't know of anyone that has returned it but if you do, you have a 100 percent money back guarantee. What do you have to lose? Just do it. You won't be sorry.
pinoyscorpion951 is offline   Reply With Quote
Old 10-07-2014, 04:30 PM   #5
garvyf22
Tonkaracing
Drives: 2013 2LS RED CAMARO
Where did you buy it from...
garvyf22 is offline   Reply With Quote
Old 10-07-2014, 04:41 PM   #6
Desertion
Drives: 2010 1LT/RS Transformer Edition
Pull the trigger! You won't regret it!
Injen CAI, Apex Catch Can, Vmax PTB, Black Ice-olator, Solo Performance Mach X-LLT Cat-Back, SLP Flat Black Gill Stripes, Satin Black ZL1 Repro Wheels, Vitesse Throttle Controller.
Desertion is offline   Reply With Quote
Old 10-07-2014, 06:13 PM   #7
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I'm With Him!!!! It's so much fun!
Eddiefuzz is offline   Reply With Quote
Old 10-07-2014, 06:21 PM   #8
BigRed585Lbs
Drives: Sierra and Tahoe
Get them while you can!
http://www.vitesse-motorsports.com/t...camaro-lfx.htm
BigRed585Lbs is offline   Reply With Quote
Old 10-07-2014, 06:44 PM   #9
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
I'm definitely interested in this. Might have to go ahead and try one out.
JantzenOKC is offline   Reply With Quote
Old 10-07-2014, 08:27 PM   #10
JGiovando
Thanks for all the input guys
Old 10-07-2014, 08:52 PM   #11
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Read the reviews.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 10-08-2014, 12:32 AM   #12
pinoyscorpion951
From here.
Old 10-08-2014, 04:12 AM   #13
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
What he ^^^^ said. No other mod comes anywhere close to adding the giddyup (including 3:91 gears) that this does. SP6 is sweet for street, SP7 starts getting squirrely. Haven't tried SP9 yet, probably this weekend. Don't wait to order as they're in very limited supply due to the availability of the GM harness that's used.
Performance:
CAI, Ported TB, Hurst ShortShifter,SkipShift Eliminator, 3.91 gears, Spohn rear TAs, BMR rear swaybar, Hedmen Shortys, Solo HF Cats, QTP Cutouts, DashLogic,Elite CC,Vitesse Throttle Controller,CurbAlert
Appearance:
20" Nitto Redlines, Rocket Muscle Boosters w/knockoff spinners,
Underbody LEDs, Footwell ,Dome & Door pull LEDs, RapidFire LED Tailights , DRL LEDs, Chrome Ghost parking lights,
Lloyds Mats, SS Kick Plates, Bowtie Hoodliner, '67 fender flags, Billet pedals, Heritage SS grill & deck emblems, rear deck blackout, custom engine brace
camguynj is offline   Reply With Quote
Old 10-08-2014, 12:21 PM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
It's one of the best mods for the LFX right now.
Helps with acceleration Can't wait for the next track day to test it out.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
