Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 10-01-2014, 04:57 PM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Talking V6 LFX Oil Change
I used this helpful link when I first started doing my oil changes.
It's very helpful and even has links on the oil filter call outs so you can buy them without much hassle.
* Don't ask me why they used a picture of a V8 front end at the top of the page. lol
Enjoy:
http://howtune.com/articles/60-chang...evrolet-camaro
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 10-01-2014, 06:38 PM   #2
Zig Zag
Drives: 2014 1LT
Great post!
Thanks for taking the time to post that up.
I've already done my first oil change at 1,500 miles so I don't really need the info but I'll bet a bunch of people will find this very helpful.
Zig Zag is offline   Reply With Quote
Old 10-01-2014, 07:07 PM   #3
xinfamousxi
Drives: Camaro 1SS 1LE
Im assuming this works on 2014
xinfamousxi is offline   Reply With Quote
Old 10-01-2014, 07:40 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Yes, same engine.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 10-11-2014, 08:35 AM   #5
Rock It
Rock It's Avatar
Drives: '12 2LT/RS
Thanks KaBoom ! that's perfect....
Mods- "Bo" ported T/B, Apex catch can, Apex scoop and W/W, K&N CAI, Magnaflow axel back, Big Worm vinyl graphics, Vitesse T/C
Rock It is offline   Reply With Quote
Old 10-11-2014, 12:08 PM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Your welcome!
Mods:
Old 10-11-2014, 01:51 PM   #7
Daywalker702
Daywalker702's Avatar
Drives: Jeep
Very useful link....
Thanks for the very detailed link, follow these instructions and you can do no wrong.
Daywalker702 is offline   Reply With Quote
Old 10-11-2014, 03:20 PM   #8
BigRed585Lbs
Drives: Sierra and Tahoe
Be sure to check for the upper filter gasket stuck in the "bell" instead of coming out with the filter.
Sure is neater than changing the filter on the V8!
BigRed585Lbs is offline   Reply With Quote
Old 10-12-2014, 09:44 AM   #9
sixtyseven
sixtyseven's Avatar
Drives: 2015 Camaro 2LT/RS 2017 XL1200C
Good link.
I changed mine yesterday for the first time with 1525 on the odometer. Was a little unsure about seating both the drain plug and filter housing because I didn't have the feel for it yet. Both came to a abrupt stop without much torque and that was it perfect no leaks.
sixtyseven is offline   Reply With Quote
Old 10-13-2014, 08:41 AM   #10
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Enjoy:
Awesome article. Good looking out for us V6 guys.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 10-23-2014, 11:57 AM   #11
BlackMamba88
BlackMamba88's Avatar
Drives: 2010 Challenger 345 R/T
Awesome, im almost ready for my 2nd oil change since I had my 2lt RS and would like to start doing them myself. Thanks a lot!
BlackMamba88 is offline   Reply With Quote
