09-16-2014, 05:59 PM | #1 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
12 LFX vs 13/14 Cam VVT positioning... Why so different?
Playing with HP Tuners recently and thought it would be interesting to compare the differences in the tunes from year to year... For the most part most of the stuff is just small tweaks here and there, but what appears the biggest change between 12 and 13/14 (13 and 14 are nearly identical) is the difference in the tables for the cam positions...
I've attached a picture of the WOT cam positions for both the 2012, and 2014 side by side... The non-WOT tables are quite a bit different also, about 6 degrees max in some areas, but the WOT tables look pretty drastic to me. I can't seem to find a multiplier, or modifier that would magically bump the 2014 table up to around where the 12 is... Very strange. Anyone have any insight on this? |
09-16-2014, 08:44 PM | #2 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I have exactly 0 insight on this but I do remember reading that 12's had a different ecm than the 13 and 14's
09-17-2014, 09:46 AM | #3 | ||
I can honestly say, you don't want to try to run the 2012 cam timing tables in a 2014... I copied them into my stock 2014 tune along with the VCP spark, and it turned it into a TOTAL DOG, absolutely horrible... Looked like it might be good on paper, but not so much. Quote:
09-17-2014, 10:26 AM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Are these all from the same model/trim?
For example are they all 1LS models, or all 2LS models? Do you know? I wonder if your 2012 is actually a 2LS and the rest aren't, and the small change can help EPA or something
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
09-17-2014, 10:36 AM | #5 |
Both the 2012 and my 2014 file appear to be Automatic, 1LT trim cars.
The 2013 file I have appears to be a 2LS, but the cam timing on the 13 vs 14 @ WOT is exactly the same, the part throttle tables, and 99% the same. I wonder if the AllData info I highlighted in red works the opposite way in the 2012/e39, ie the Intake cam starts fully advanced, and gets retarted as the numbers climb in the tables, VS maybe starting fully retarded in the 14/e39a and get advanced, which is why the numbers from the 12 don't work in a 14? I have no clue. But I'd like to learn. |
09-27-2015, 02:00 PM | #6 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
10-02-2015, 11:02 AM | #7 |
ENGINE > AIRFLOW > VARIABLE CAM SHAFT
The tables shown are the WOT, there is also a bigger table for part throttle driving for LOW/MED/HIGH which is based on barometric pressure. |
10-02-2015, 12:44 PM | #8 |
thanks
10-02-2015, 07:54 PM | #9 |
Drives: Chevrolet Corvette C6 Z06 Join Date: Oct 2010
No matter what values are set at, there is always more power to be had with playing with these tables.
GM retards and advances their cam profiling for mileage. I've gained at least 15whp from tuning these tables alone on a bolt on car. |
10-02-2015, 08:16 PM | #10 |
Did you find you increased or decreased or both the factory numbers
10-02-2015, 08:42 PM | #11 | |
On a Gen5 pick up with a VVT cam, increasing the values actually increased around 28wtq! https://instagram.com/p/8G-pTem8nd/?taken-by=mep_q8 |
10-03-2015, 09:26 AM | #12 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
I know nothing about tuning but I was thinking this could have been changed to correct some of the many v6 misfire issues I've read about on here?
10-03-2015, 04:25 PM | #13 |
So, anybody mod these on a v6?
10-04-2015, 03:03 AM | #14 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Yes, it's one of the things I used to shave 0.7 seconds off my ET. They are used to broaden the powerband.
