08-01-2014, 03:41 PM | #1 |
50th Anniversary Vert
20x10.5 Front offset
I have been trying to confirm offset for a 10.5 front/back setup (I am OCD).
I trawled through various forums and websites and came up with these variations. 20x10.5 5x120 +35 front (Niche Apex/Milan) 315/35/20 rear and 275/40/20 front tires 20x10.5 5x120 + 25 machined to +27 (Rohana RC-5) 20x10.5 5x120 + 24 (BBS) - not sure if this worked out. 20x10.5 5x120 + 27 (Vossen CV3) Tire size would be close to if not 315/35/20 rear and 275/40/20 front. Which of the above would require no spacers, no rubbing (not lowered) and be flush with the fender?
08-03-2014, 07:31 AM | #2 |
I believe the exact offset will vary based upon the wheels you choose. Any vendor or the wheel manufacturer should be able to tell you what you need to make the wheel fit guaranteed. If you can't get them to guarantee the fitment then you should find another place to buy. Also, I am not sure if a 275 tire will fit on a 10.5" rim. Looking at the recommended tire size stickie that rim should run a 305-315
08-03-2014, 09:38 AM | #3 |
Drives: RRM RS v6 Join Date: Mar 2014
A 275 absolutely fits a 10.5. It's slightly stretched, but it works.
Magnaflow X - pipe
MRT V2.0 CAI Intake BARTON SS Airlift Suspension V2 Niche Targa 20x10.5 |
08-03-2014, 12:15 PM | #4 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
20x10.5 with 35 I dont think will work up front.I have 1/4" clearance with 20x10s with 35 offset and 285/35 tires and 1.2 negative camber with coilovers that give me 10mm extra clearance.
08-03-2014, 12:37 PM | #5 |
I'm putting 20x10.5 +35 niche targa all around with 275-35-20, but I'm bagged.
Magnaflow X - pipe
08-03-2014, 01:16 PM | #6 |
Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
20x10.5 with 24 offset works thats what i run with 295 nittos invos for the front
Black magic woman, don't turn your back on me baby!
08-04-2014, 08:51 AM | #7 |
Drives: 2010 Camaro 2SS/RS , 1967 camaro SS Join Date: Jun 2010
I'm running Niche GT5 20x10.5 with a +20 up front with 275/40r20 NT05
08-05-2014, 02:17 AM | #8 | |
Quit being a pu$$y
08-13-2014, 01:05 PM | #9 |
So worst case with 20x10.5 5x120 +35 front with 275/40/20 front tires is that I might need spacers to get the wheel flush?
08-13-2014, 01:18 PM | #10 |
Drives: G5.R Join Date: Sep 2010
The BBS offset worked out with 295 tires in front.
08-13-2014, 01:25 PM | #11 |
I love those BBS wheels.
An offset of +35 I am limited to 275/40, but an offset of +20 lets me run 295 tires?
08-13-2014, 01:53 PM | #12 |
35 up front. Really depends how low you are. I'm on bags 20x10.5 35 275/30
Magnaflow X - pipe
