07-20-2014, 09:22 PM | #1 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
Which Spark Plug???
Looking for some advice, I was talking to a local shop about a dyno tune and they said I should change my plugs. I don't have it in front of me but I seem to remember them saying NGK TR6? (but I could be wrong on that)
Anyway, my mods are just CAI, longtubes w/ off road connectors and NPP, no cats, no resonator. Do I need to change the plugs from what came in the car? Thanks, Cady |
07-20-2014, 09:23 PM | #2 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
Nope. Leave them stock.
07-21-2014, 08:28 AM | #3 |
Drives: ETMC built 700+hp Twin Turbo LS3 Join Date: Apr 2010
you're fine with the stock ones. Once you go boosted you'll need colder plugs
07-21-2014, 04:46 PM | #4 |
Echale Gas [COTW 3/10/14]
Drives: 2010 Camaro SS/RS Supercharged Join Date: Aug 2010
I have TR6 spark plugs...mesh pretty good with my supercharger
They are a cheap replacement, I would recommend changing them if you are high mileage already. I changed mines out at 85,000 I think. I operate under the mentallity of changing things out ahead of time before something happens.
Kenne Bell 502 rwhp/ 471 rwtq at 9psi (daily driver...for now) Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers |
07-21-2014, 07:01 PM | #5 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
When you go boosted, switch to non projected tip plugs. BR6EF for moderate boost.
Another 1 of 371 '12 T3 LS3 M6's built.
07-21-2014, 08:57 PM | #6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
At your power level and quite a bit further than you are, stock plugs are perfectly fine. You won't gain anything by going with different ones, other than possible issues. If you go FI or nitrous, you'll want to look into colder plugs.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-21-2014, 09:15 PM | #7 |
It's in the hole!
Thanks guys, I have no further plans at this time and my plugs only have 18,000 on them so they are going to stay in.
