Vararam
Old 07-18-2014, 01:09 AM   #1
johandepuydt
johandepuydt's Avatar
Drives: Camaro 2012 45th edition-Edelbrock
Engine blew up
My friend and I have both a Camaro 2012 SS L99.
Mine is a 45 th aniversary and his is a convertible.
We both made the same changes to the engine.
E-force supercharger, smaller pulley, bigger injectors, CAI, Kooks long tube headers, CAT, Lingenfelter GT9, DOD delete kit, LS3 conversion in fact...690 Hp on the dyno.
Now thuesday I was cruising behind him in Germany when he floored the gas pedal. On some highways in Germany there is no speed limit so it's nice to go playing there
After a few seconds there was a little smoke from the left exhaust when shifting. A little later I could no longer see a thing and oil was spreading on my windshield.
His engine blew up
Now the car is still in Germany on a trailer waiting for the insurance to get it back to Belgium.
I made a little movie with my phone for so far it was possible to get under the car.
http://youtu.be/eKYHiYLbGWA
I think this engine is dead?
johandepuydt is offline   Reply With Quote
Old 07-18-2014, 01:25 AM   #2
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
I would start with the tune and see why it let the motor hurt itself...
2013 ZL1 #7860 is offline   Reply With Quote
Old 07-18-2014, 01:31 AM   #3
johandepuydt
The tune is the same as mine. Mine makes 692 Hp and I already did about 10.000 Km's with this conversion and the tune.
What I forgot to mention is that his engine modifications are only two weeks old, except for the supercharger.
The hole in the oil pan makes me worry.
Old 07-18-2014, 01:41 AM   #4
2013 ZL1 #7860
Generic tune or dyno tune? Fuel?
Old 07-18-2014, 01:45 AM   #5
songsj
Drives: 2015 2SS/RS Summit White
When you start doing these kind of mods and putting this much stress on engine parts things can break. Brand new NASCAR engines blow up from time to time with very few laps on them and they are designed for the abuse they are given. You'll need to tear her down and see what failed and go from there. While what happened to his is cause for concern with yours, it doesn't mean yours is doomed to fail. If I were you I would surely want to know what failed in his and try and determine if it was just a faulty part or have you created a situation where the strength of engine parts are mismatched and going to cause you problems with hard use.
songsj is offline   Reply With Quote
Old 07-18-2014, 01:46 AM   #6
johandepuydt
Dyno tune done by EDS motorsport who tunes Camaro's in the States.
Fuel is 98 octane.
Old 07-18-2014, 01:52 AM   #7
johandepuydt
What you say is correct and I am a concerned for my ride.
Old 07-18-2014, 02:09 AM   #8
johandepuydt
The video.....
Old 07-18-2014, 05:41 AM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
You can see the hole in the bottom of the engine where it looks like a probably a connecting rod came apart and went thru the bottom of the engine.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-18-2014, 06:00 AM   #10
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
E-force strikes again
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
Trob85 is offline   Reply With Quote
Old 07-18-2014, 08:11 AM   #11
rodfone
rodfone's Avatar
Drives: 2012 2SS/RS
What I don't understand with people adding power to the top half of the motor and not beefing up the bottom end to handle the additional stress
rodfone is offline   Reply With Quote
Old 07-18-2014, 08:16 AM   #12
rare991
rare991's Avatar
Drives: 2014 SS 1LE
exactly! Did you expect almost 700hp to hold up on a stock bottom end for long???
rare991 is offline   Reply With Quote
Old 07-18-2014, 08:32 AM   #13
Trob85
Svt lol
Trob85's Avatar
800 is holding up just fine in a few cars around here so I don't know what you're talking about. We even have a guy at 915 rwhp stock bottom end. You'll be surprised how much these engines can handle with sufficient fuel and a perfect conservative tune. Is it smart to build the engine for boost yes, but is 700 hp isn't a lot for these engines (no) though it's starting to push the limits.
Old 07-18-2014, 08:47 AM   #14
Mr Monte
Mr Monte's Avatar
Drives: 2014 Chevy SS
When my son was 16 we had a 74 Camaro Father/Son project. Original plan was a mild 400hp 454 BBC until he wanted to go with a big cam so reminded him you are only as good as your weakest link and ended up replacing the following due to his cam change:
* Bigger int/ext valves
* Ported/polished heads
* Forged H-beam rods
* balance rotating assembly within .0 grams, even the 1/2 weights were within .0 grams
* Custom driveshaft/u-joints rated at 800+hp & drive shaft loop
* Upgraded 10 bolt rear to 30 spline HD axles, HD Mosler axles, disc brakes, 3" wheel studs
* Welded in subframe connectors
* Rebuilt the Turbo 400 tranny with HD parts & 3,500 stall
* Vacuum can to help with the power brakes
While we were at we also:
* Tubular front control arms
* Big front/rear sway bars
* Quick ratio steering box from Gen 3 WS6 Trans Am
* Dyno Mat on floors, trunk, door skins, firewall
* dual electric fans
* 3" steel cowl hood to clear 4" tall air fliter
* Big stereo with amps, subs
The 454 block we started with was a 4 bolt main with forged steel crank
It's nice to have options.
Mr Monte is offline   Reply With Quote
