Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 07-08-2014, 12:51 AM   #1
SpeedyMedic
SpeedyMedic's Avatar
Drives: 2010 Chevy Camaro SS
They got into my car w/o setting off my alarm?
Can someone explain something to me? My car was broken into and they stole what was easy to get. No windows were broken. The car was locked. My alarm never went off. Even though it wasn't anything major, the fact that they were able to get this close without my noticing bothers me. I'm still unsure how someone could get into my vehicle without my knowing or setting the alarm off.
Has anyone else had this problem?
So why does it say drive like a girl?
It's simple. People tend to get out of the way faster if a woman's behind the wheel.
SpeedyMedic is offline   Reply With Quote
Old 07-08-2014, 02:55 AM   #2
Crazyhorse6901
Turbine Maker
Crazyhorse6901's Avatar
Drives: 2012 Camaro 2LT-RS "LFX"V6
They have a device that will bypass the alarm system.
Crazyhorse6901 is offline   Reply With Quote
Old 07-08-2014, 10:39 AM   #3
SpeedyMedic
So there's really no reason to have an alarm? Does anyone know of a better system? I'm kind of frustrated with a thieves ability to take my things so easily.
Old 07-08-2014, 11:02 AM   #4
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
When you got in had the tamper alert been activated? Its possible they had one of those frequency generators that send out millions of unlock codes and they found yours that way.
The Bird is the word!
Old 07-08-2014, 11:16 AM   #5
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
My alarm
Alarms are only a feel good device. Thieves will get it if they want it. Out of site out of mind.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 07-08-2014, 11:46 AM   #6
baum
Drives: 2013 1LS, 2013 Ram 1500
i know you would probably swear that you locked it, but are you truly sure?
and have you tested to see if your model is actually an alarm? they way to test is lock it with the fob. press the lock button 2x. wait a few minutes with the window down open the door from the handle inside do not hit the lock button. if the horn honks you have an alarm. if it doesnt you dont
baum is offline   Reply With Quote
Old 07-08-2014, 12:01 PM   #7
Angrybird 12
They all come with the alarm. You can tell if it's activated 30 seconds after locking the doors by a red LED flashing in the light sensor dome.
Old 07-08-2014, 12:06 PM   #8
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
So where do you get one of these devices? How much do they cost?
I'm sure they fall into the "tools for commission of a crime" category, and the NSA will add this to my permanent record for quality purposes...
But I would like to see a demonstration.
op - my money is on left unlocked or someone used your key fob.
Southern Comfort is offline   Reply With Quote
Old 07-08-2014, 12:32 PM   #9
Angrybird 12
I've seen news reports about it being done, not sure if it works on newer cars though.
http://abcnews.go.com/Technology/bre...ry?id=17367442
Old 07-08-2014, 01:05 PM   #10
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
They're devices you make, you can't buy them, radioshack parts..
Knockoutpie is offline   Reply With Quote
Old 07-08-2014, 01:36 PM   #11
customaudioman
Drives: burnt orange
This happen more with older cars "code grabbing". I havent seen it much with newer models. Me personally I always add aftermarket alarms to all my cars. then added tilt sensors, glass break sensor and proximity sensor. biggest thing is don't leave thing visible on seats and dash.
customaudioman is offline   Reply With Quote
Old 07-08-2014, 02:00 PM   #12
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Code grabbing devices don't work well on newer cars that have "rolling code" type receivers. This type of remote works by sending out a different code each time the transmitter is pressed. The receiver has an algorithm that tells it which code is being sent, and what the next code sent will be. Code grabbers can only receive one frequency, and cannot encode and send rolling code information.
jeffa is offline   Reply With Quote
Old 07-08-2014, 02:10 PM   #13
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Did you program your smart phone to lock and unlock your car ? If they want to steal it ,they will . All you can do is slow them down.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 07-09-2014, 09:57 PM   #14
SpeedyMedic
I made sure to lock it after I checked for my sister's purse. I don't usually leave my car outside, so I double checked.i didn't see any evidence of tampering aside from my things being gone. I know the alarm works since it's been set off by a passenger in the past. I couldn't tell you how it happened. It's a newer model and shouldn't have been so simple but it seems that it was. Sadly, I have no idea what to do to prevent this in the future.
alarm systems, anti theft, anti theft protection, b&e, theft
