dave@hennessey
Old 05-16-2014, 10:16 AM   #1
Bryaniskoo
Drives: 2010 RS
Front left tire wiggle.
2010 RS
The car is fine from a stop. But as soon as I hit a bump the car starts tugging back and fourth to the left. Pushing around the road. I jacked it up and tried to wiggle the wheels doesn't seem to be any play in them.
Anyone had this before?
Bryaniskoo is offline   Reply With Quote
Old 05-16-2014, 02:04 PM   #2
Bryaniskoo
Drives: 2010 RS
bump
Old 05-16-2014, 03:13 PM   #3
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
When I try to check for free play in the front end, with the car jacked up, I like to use a 4-5 foot peice of 2 x 4 for leverage. Also check sway bar end links.
Dimitrim is offline   Reply With Quote
Old 05-16-2014, 03:39 PM   #4
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Are the lugnuts tight?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
