05-06-2014, 07:01 PM | #1 |
Drives: 2012 ZL1 Join Date: Feb 2014
Metra 99-3010s relay question...
Howdy folks....purchased a used Metra 99-3010s install kit used off of ebay that is in pretty good shape. I downloaded the manual, but the problem is there is this relay that (apparently) replaces the built in turn signal sound/door chime, and it's not mentioned in the manual at all. The problem is that it's not connected to anything in the wiring harness and was hoping some of you good folk who have either done this yourself or had it done might know how/where to connect it.
Any pics of wiring the relay would be super helpful. Thanks guys!! |
05-06-2014, 07:59 PM | #2 |
I got pretty confused on my (former) Metra kit. All the relay does is CLICKS! That's it! It's a noise maker. :/
I don't have mine anymore so I really can't say where it was hooked up to in the harness, but if you do find it, don't be as baffled as I was when it only shows 2 wires hooked to it.
{sold} -- 2011 Camaro 2SS/RS - Black on Black. Kooks catted LT's, CAI, Accell 9070c ceramic wires, Barton shifter, custom catback w/Dynomax VT's, quad tips, Pfadt springs/sway bars/trailing arms, Diablosport tuner {Lew tune}, 3.91 gear's, Energy cradle bushings.
05-07-2014, 12:00 PM | #3 | |
05-07-2014, 02:48 PM | #4 |
Drives: 2013 GAZ 2SS/RS Join Date: Feb 2012
If I remember correctly, it had spade connectors on that relay, and only 2 wires were connected.
So those wires should be easy to find as they will be the only 2 with spades, and they go to the coil wires of the relay. If you were unlucky the previous owner cut the connectors off, but then again, all the other wires are covered in the manual. The 2 remaining are what you are looking for. You can download the manual from Metra for free, and that covers all the other wires. Like Black Out pointed out, you really don't need to use that relay if you don't want to hear a traditional click sound when your turn signals are on.
If you see it, get it, for tomorrow it may be gone!
05-08-2014, 01:05 PM | #5 | |
So when you say I don't really need to use the relay to hear the 'traditional click sound' what does the alternative (if any??) sound like? I guess I don't really care as long as there's a click. to tell me I have my signals on. |
05-08-2014, 07:04 PM | #6 | |
No relay no clicky. Or you could wire in a siren. Piss off your passengers.
05-08-2014, 07:25 PM | #7 |
Drives: '21 TRx '22 ZLe Join Date: Oct 2013
if the relay is marked, Pin 86 and Pin 85 are the ones you want to make the relay open/close. This would supply the clicking, but I could not imagine that being loud enough to hear buried in the dash.
As to where they connect to the harness I have no clue.
2014 Camaro 2SS/1LE AGM/768rwhp
Recaro's, Custom Autometer Gauges, Hotchkis 1" Lowering Coils, CAi Intake, Elite Catch Can's, 1 7/8" StainlessWorks LT's w/Hi Flo Cat's mated to factory NPP Exhaust, 160* Thermo, NightFury Cam, 2.9l Whipple on Meth @ 11lbs, JoeGibbs LS30 in the CrankCase, Built by Nick, Steven, and Tuned By Shawn at Lethal Racing.... |
05-10-2014, 12:00 PM | #8 |
Well, you've gotten me halfway there, ha ha! Thanks!
