Roto-Fab
Old 04-23-2014, 11:17 AM   #1
Babich9
Drives: 2014 2SS/RS 1LE
Kooks header question
Did any of you guys use the gaskets that came with the headers or did you get another set from GM? Also did you use the header bolts that come with or did you get others like ARP? I just wanna make sure I use quality! Thanks
Babich9 is offline   Reply With Quote
Old 04-23-2014, 11:22 AM   #2
Pace
Lifestyle = Deathstyle
Pace's Avatar
Drives: 11 SIM 2SS/RS
Send a message via AIM to Pace
I bought new gaskets from dealer - OEM are the best. Re-used the header bolts.
11 2SS/RS
Pace is offline   Reply With Quote
Old 04-23-2014, 11:44 AM   #3
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I bought om gaskets but used the header bolts that cane from kooks.
newagemuscle is offline   Reply With Quote
Old 04-23-2014, 11:52 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
I reused both the OEM gasket and the bolts. My car only had about 3,500 miles at the time. I had no issues with it.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal
caverman is offline   Reply With Quote
Old 04-23-2014, 02:58 PM   #5
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
I reused the stock OEM gaskets and the stock OEM bolts that were on the stock manifolds.
Absolutely no leaks and after 2 weeks i went to re-tighten the bolts but they were still tight.
My 2 cents, dont waste the money. Just be careful during diss-assembly so you dont break anything. Pull the spark plugs out before you remove the manifolds so you dont accidentally crack one (super common) and youll be good to go!
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 04-23-2014, 09:50 PM   #6
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
The bolts are good. Gaskets are not. I would reuse or get new OEM gaskets.
MarylandSpeed is offline   Reply With Quote
Old 04-23-2014, 09:52 PM   #7
HoustonTx2ss
HoustonTx2ss's Avatar
Drives: 2010 2SS RS M6
Same here. Re-used OE gaskets but I used the new bolts.
2010 SS/RS M6-LS3 -- Mods -- CAI, V-Max Throttle Body, Apex Scoop, SP 1 7/8 Headers, HF Cats, Magnaflow Tru-X.
Dyno Tuned by Mike (FAST Automotive) and Matt (FSP)
BMR Suspension - Rear - Cradle Bushings (Pro Version), Upper Control Arm Bushings, Diff Bushings, Trailing Arms, Toe Rods, Drop Spring, Koni STR.T Struts.
HoustonTx2ss is offline   Reply With Quote
Old 04-24-2014, 08:26 AM   #8
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
I reused the OEM, but one side leaked. Bought new OEM, all good. I do believe one side is very slightly warped though (bought the headers slightly used)
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
f5journal is offline   Reply With Quote
Old 04-24-2014, 08:46 AM   #9
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I bought new as they are designed to compress when installed. Most have no issues reusing, but they are cheap so no question to buy new OEM for me.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-24-2014, 11:38 AM   #10
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
New OEM gaskets are cheap insurance against leaks. Some can get away with reusing them, but for the risk of having to go back and replace them if there was a leak, It's just not worth it IMO. The hardware that comes with them is good, but definitely pick up some new gaskets.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 04-24-2014, 07:26 PM   #11
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
Use OEM gaskets - new or used and re-use stock header bolts. It's also a good idea (but not necessary) to put a little anti-seize compound on the bolts when you install your headers.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
