04-23-2014, 10:51 AM | #1 |
275 on the front
I have the ZL1 factory reproductions. 20x9 on all four. Will a 275 fit upfront on the 9" wheel?
I see plenty of people running them with a 10" wheel. Just making sure before I order tires. Thanks |
04-23-2014, 11:18 AM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2013
You'll be fine....you can run a 275 on a 9" rim with no issues. The stock rear's on the SS are 275's and they are running on 9" rims. I have a 275 upfront on mine with a 10.5" rim.
04-23-2014, 11:41 AM | #3 |
I have the Factory repos on my car with a +23 offset. My rims are 10 inch rims but the 275s will fit on a 9 inch rim. It is going to come down to your offset on your rims, If you have +23 you will be fine. 275s should be ok, if they were 285s or 295s thats another story.
04-23-2014, 11:48 AM | #4 |
Yea I know the 275 will fit on the 9" wheel. I was talking about the tire and wheel fitting under the car with no rubbing. Sorry for the miscommunication
04-23-2014, 01:53 PM | #5 |
Drives: Camaro RS/SS, 996TT, E90 335i Join Date: Feb 2012
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
What is the aspect ratio on the tires and do you know the offset? Should be just fine if its a 275/40, but we will need to know the offset to be sure.
04-23-2014, 08:25 PM | #6 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
YES, a 275 works just fine....I have been running 275's on stock 9" wheels in the front of mine for nearly 2 years. no issues at all. actually it made the car handle a lot better.
04-23-2014, 08:56 PM | #7 |
Thanks guys! It will work I swapped one rear wheel/tire with a front and everything was all good! I appreciate all the help and fast replys
10-30-2021, 12:49 AM | #8 |
Drives: 2010 Camaro SS Join Date: Oct 2021
Would I be able to run a 275/40 up front with a 33 offset and bmr lower springs? What about 305/35 in the rear. Thanks in advance
10-30-2021, 12:32 PM | #9 |
Drives: 2010 2SS & 2013 ZL1 Vert Join Date: Mar 2015
That's gonna be close, but it'll fit. I actually have a similar setup on my SS. I took the rims off my Z (to replace with Z28 rims) and put them on the SS. I have 315's on the rear, though.
11-11-2021, 10:56 AM | #10 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
i ran a stock rear tire up front no problem on a 20x9
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-11-2021, 01:20 PM | #11 |
11-11-2021, 03:51 PM | #12 |
You will be just fine..
