04-21-2014, 09:22 PM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Mar 2014
Help improve 60ft
Hi guys. This is my first time running at the strip in a high powered rwd m6 car. I had a good mph but I think I'm leaving a lot at the start of the run. Can you guys give me any pointers?
Car is bone stock Rear tires were dropped to 25 psi Launches were at around 2k (anything higher just spun n lower bogged) |
04-21-2014, 09:29 PM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Seat time. Get a remote clutch fluid reservoir for your car and keep fresh fluid in the system. Your going to have to play around with the clutch and rpm until you find what works for you. Its more about feel more than anything since tracks vary on prep and hooking ability.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
04-21-2014, 09:58 PM | #3 |
Drives: 2012 SS LS3 Join Date: Nov 2011
A good starting point is to find out which track in your area has the best starting line traction. Some track officials take great pride in having the best track prep around, others just blow the dirt off and bring the cars out. It makes a big difference.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph Thunderhill 2:22.242 |
04-22-2014, 06:33 AM | #4 |
Thanks for the info BO WHITE. that might explain why on the next pass the clutch pedal didn't come all the way back out so I had to abort the run. I will look into getting one.
04-22-2014, 06:35 AM | #5 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Def look into the separate clutch fluid reservoir, JDP has them.
Also Lingenfelter sells a clutch pedal return spring that is supposed to be pretty sweet.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
04-22-2014, 07:08 AM | #6 |
I wouldnt worry about the return spring. Its a bandaid for a problem lurking somewere else, the pressure plate and/or dirty fluid. Keep your fluid clean and flushed and if you still have a pedal that wants to hang up just go ahead and start shopping for a good clutch.
04-23-2014, 01:40 PM | #7 |
2.52 is terribly slow. I have had cars that run high 16's get a 60' in the 2.4 range. You are spinning like crazy most likely. If you ease the car out and slip the clutch a little before squeezing the throttle to the floor, your 60' time will be much better. 2.0-2.1 is possible on street tires so practice.
04-23-2014, 03:24 PM | #8 |
I will definitely try easing out and then squeeze the pedal. It was spinning like crazy. I also noticed that my wifes G5x had 2.4 60' times granted it was awd and automatic.
Does anyone know if the 1LE has the no lift shift feature like the ZL1? |
04-23-2014, 04:58 PM | #9 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
If you are on stock tires, I would try to get the 60 down to no worse than 2.1. Sure if you can click off a high 1.9 that's great I just don't know what the stock tires can do on your car. Did you look at the lists to see what others have done?
Not to rub it in but I went 1.95 all stock in my slushbox.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
04-26-2014, 05:32 PM | #10 |
Wowzers 1.9. I am on stick good year super cars. They did awesome at Putnam on the road course. Next time out ill shoot for a 2.1. I think I need to get the clutch out faster. I was reading clutch should be fully out before you pass the tree... I'll post next weekend if weather permits.
04-30-2014, 06:32 PM | #11 |
chevy pride
on my stock tires i would launch at around 1500/2000 range and just pop the clutch and lob the car out and it would like nose over a little and lay into it. lobbing the car always did good for me on the stock tires. i was pulling 1.8x pretty consistant. but i had a good track too thats the main thing. but try diff things if u keep doing the same thing over and over u will never find a way that works. just keep at it and get someone at the track to kinda help ya figure it out that knows what to look for and listen for.
check out ky speeds fb page https://www.facebook.com/kyspeed |
04-30-2014, 08:43 PM | #12 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
Drive around the water box and haze those tires off a little. With that 60 ft I wouldn't be surprised if your tires were wet or that is one slick track.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
05-05-2014, 01:10 PM | #13 |
@Dekan, Yea it was pretty slick, i tried launch control which didn't turn out well, i tried leaving at 2k and even other camaro's who had run low 13s on other tracks were saying they couldn't hook. I will try just popping the clutch at 1.5/2k to see what that nets. I think i am going out again this friday - I will post results. Now that they have had a few events it should be some good rubber down now.
05-05-2014, 01:29 PM | #14 |
@ vader when you say haze them do you mean just spin them on the ground in fron of the water box?
