Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 03-12-2014, 10:57 PM   #1
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
14 MPG
Hey guys, so yes its another MPG thread
So my car is getting 14mpg Thought it would be a small thing that would pass but its been this way for about the last 3 monthes of its driving cycle. Its stored currently but I guess the last month of driving did have winter blend fuel. Without winter blend I would say it was about 15-16 mpg.
The car was driven the same way it was before and it was achieiving 21mpg
The car now has 50,000km (31,000 miles)
I havnt changed the plugs yet, I did do a seafoam treatment back in September.
Mods on the Car are the following
Vararam
Solo Cat Back
Black ICE
All these mods were installed years ago so dont think I can blame the mods.
SO heres my dilemma, im not sure where to start to isolate the issue for the terrible MPG.
Heres my possible problem areas:
Air leak on the manifold from the black ice?
Bad plugs
Maf Sesor? (it may have gotten sea foam on it)
I mean I dont know what else can cause it to be soo bad. This has occurred through several tanks of gas.
Also want to say sorry in advance for the structure of this post, lack of sleep.
Is there anything else that could be causing it?
No CELs, no mis fires that I can feel, and yes I did the usual checks such as tire pressures, air filter etc.
Any help or input would be very much appreciated
Ps anyone know how to test the manifold for leaks? Ive heard of smoke methods
CAMARO
Consult your doctor before taking Camaro
Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations
If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help
CAMARO Bringing excitment back into the Garage
TJ91 is offline   Reply With Quote
Old 03-13-2014, 04:19 AM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Last time you cleaned your air filter?
To check for leaks, spray around the manifold with some carb cleaner... see if the idle changes.
Get some MAF cleaner and clean the MAF.
scrming is offline   Reply With Quote
Old 03-13-2014, 05:11 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Then check after a couple of tank fulls of new fresh gas and make sure your checking the MPG correctly. Any one tank can give you miss readings. If you did not fill it the same everytime. I know becasue I have every tank full recorded and see the numbers jumping around depending on the total fill up, how it was driven, temperature plays a huge roll too.
rtcat600man is offline   Reply With Quote
Old 03-13-2014, 05:04 PM   #4
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Yeah I've cleaned the air filter and it was still getting bad mpg
I have a feeling it could be a leak in the manifold so I'll try your method! Thanks alot John
And the maf I think is my problem. Going to bring the sensor into work and clean it
Thanks again!
Yeah I'm sure there were some inconsistencies with driving and gas but it's been averaging about the same 14-15mpg for a few monthes before I stored her. So now that she's coming out of storage soon I want to get it taken care of and handled
Thanks alot for your input guys. Car won't be out for a few weeks but definitlt going to start trying to tackle the problem
Thanks for the feedback, going to update this thread in a few weeks hopefully with some imptoved numbers
CAMARO
Old 03-25-2014, 05:49 PM   #5
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Alright guys took apart my Vararam filter
The lower belly is covered inthick grime from the seafoam and dirt passing through the filter
So going to clean it all and the maf and hope it helps
I guess it finally proves how much dirt is passing through the oiled filter :o
CAMARO
Old 03-25-2014, 06:00 PM   #6
rtcat600man
YUCK..............I sure hope that is it, bet that can't be helping the situation out.
Old 03-25-2014, 07:57 PM   #7
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Dude I need to post some pics
I was like wtf ?!
It looks like it swam in a mud bath
CAMARO
Old 03-25-2014, 07:58 PM   #8
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Makes me question the VR filter
And there is a video I need to post to from YouTube to get others opinions
CAMARO
Old 03-25-2014, 10:19 PM   #9
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
CAMARO
Old 03-25-2014, 10:19 PM   #10
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
any thoughts on that video?
CAMARO
Old 03-25-2014, 10:58 PM   #11
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Is the vararam filter oiled or paper?
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 03-26-2014, 12:02 AM   #12
c_cook94
c_cook94's Avatar
Drives: 2011 Rally Yellow 1LT
The Vararam is supposed to be oiled. From that video I'm not sure if it was oiled or not. That was a lot of dirt passing through.
c_cook94 is offline   Reply With Quote
Old 03-26-2014, 09:23 AM   #13
strtsol1109
Drives: ZTS pearl in autoflex
Where would you get other filters for the vararam?
Full MBRP 3in exhaust, Vitesse TC, BBK LT, black iceolator, VMAX TB, vararam, LG coils, zl1 reps, zl1 front bumper, zl1 grille, zl1 rockers, CF Copo hood, CF trunk, gm blade wing, HAVOC diffuser, APR splitter, dipped SS calipers
strtsol1109 is offline   Reply With Quote
Old 03-26-2014, 09:51 AM   #14
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Wow that's a lot of sediment ?
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
