Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 02-23-2014, 09:12 PM   #1
taymiddleton
Drives: 2012 Camaro LS
Angry Where is the Thermostat located on a 2012 V6
My camaro is overheating and the heater is blowing out cold air!!
taymiddleton is offline   Reply With Quote
Old 02-24-2014, 07:09 PM   #2
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Engine Coolant Thermostat Housing Removal
Zoom and Print Options
1. Remove the heater inlet/outlet pipe assembly bolts.
2. Remove the heater inlet/outlet pipe assembly.
3. Remove and discard the heater inlet/outlet pipe assembly O-ring and gasket.
4. Remove the thermostat housing assembly bolts.
5. Remove the thermostat housing assembly.
6. Remove and discard the thermostat housing assembly O-ring and gasket.
etmx183 is offline   Reply With Quote
Old 02-24-2014, 08:01 PM   #3
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
taymiddleton,
Thanks for your post and I apologize for your overheating concerns. Have you contacted your local dealer to schedule an official diagnosis? You may also feel free to PM me your VIN so I may check my resources for any known issues.
Kind regards,
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 02-25-2014, 05:57 PM   #4
taymiddleton
etmx183,
ohh So its behind the engine! Thank you all the diagrams i was looking at was showing that it was in the front. i guess they are not in the same place as the v8
Old 02-26-2014, 09:44 AM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Have you checked the coolant level? Overheating engine plus no heat may be due to low coolant level, so that there's no coolant up in the heater core.
This has happened to me on some other cars that don't have a visible surge tank.
Old 10-05-2023, 07:04 AM   #6
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
I was losing coolant too, since the car was new. Many years later found the source, since it was getting worse you couldn't miss it. It's that pipe at the top front of the engine that the coolant hose connects to. You will have to remove it and replace the o-ring where it mounts. I found it easier to just order a new one, it's not called what you would think it would be called
https://www.rockauto.com/en/moreinfo...pt=10337&jsn=8
blackswan is offline   Reply With Quote
thermostat
