02-15-2014, 09:42 AM | #1 |
Hmm...Something Clever
Drives: Blac on Blaq on Blak 2012 Camaro LS Join Date: Dec 2009
Fuel injector cleaner
Do u guys use this stuff?
Adjustments: 20% tint all around, Emblem Pros Dash plaque, Rockford Fosgate P-300/12 |
02-15-2014, 01:12 PM | #2 | |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
it is additional detergent which is already in your fuel. If you want to clean fuel injectors you normally detach the fuel system from the fuel rail and attach it to a machine or pressurized vessel that sends highly concentrated cleaner though the system.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
02-15-2014, 01:15 PM | #3 |
Absolute waste of money. If you have to use it on a new Camaro or any other new car something is very wrong
02-15-2014, 01:30 PM | #4 |
I use this in my lawnmower gas?
http://shop.advanceautoparts.com/web...nol#fragment-1
02-15-2014, 02:30 PM | #5 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
The only stuff I regularly use is Seafoam.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
02-15-2014, 02:54 PM | #6 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
Wow, surprised by the comments.
Guess you guys won't be doing 35 MPG HWY like me.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
02-15-2014, 06:07 PM | #7 |
USN-MSC
It is not a waste of money...it's called taking care of your car.
“The winner ain’t the one with the fastest car, it’s the one who refuses to lose.”
02-15-2014, 07:07 PM | #8 |
Drives: Camaro 2SS/RS Join Date: Sep 2013
If you use Chevron gas, it is already in the gasoline, that is their proprietary additive.
Seafoam is a joke, ha! |
02-15-2014, 07:17 PM | #9 |
Drives: 2014 camaro ss ,1967 chevelle ss, Join Date: Sep 2013
clogged injector is very rare, unless you get your tank sugared or something. I never use snake oil in anything of mine. we have it at work and I promise you won't be able to tell any difference, just like nitrogen in the tires. don't know how many cars I see a week with that crap in them and pressures are still off. now before you guys start....nascar changes tires a lot, it will hold for awhile but not 3000 miles
02-15-2014, 08:03 PM | #10 |
Drives: 2014 AGM 2SS/RS 1LE Join Date: Aug 2013
I must be in the minority as well although not in the Camaro (haven't driven it enough yet). I use Lucas oil injector cleaner in my Jeep about every 4 tanks. When we take our Acura on a road trip, I run a single can of BG 44K through it when we leave. 44K is like $24 a can so I only run it when we road trip. I notice a difference in the Acura for sure when I run the 44K through it at 125k. My Jeep has 95k on it and runs stronger than any Jeep I've driven. It maybe snake oil but I don't think it's hurting anything... No opinion on the Chevron stuff though.
2014 2SS RS 1LE
02-15-2014, 08:23 PM | #11 |
Drives: 2010 ss. 1990 RS the faster one. Join Date: Jan 2011
You guys with the direct injected v6s should definitely be using this stuff at least a couple of times a year. Remember, your injector tips are in the combustion chamber. It's a hostile environment. I would use either techron or Gm fuel injector cleaner. If you only fill with.top tier fuel you should not worry about it.
Vararam, XS Power longtubes and exhaust with Magnaflow mufflers, 1LE gears, Vengeance Racing spec'd comp cam with all supporting valvetrain upgrades, Melling Pump. QTP cutouts. 480rwhp.
02-15-2014, 08:23 PM | #12 | |
Drives: 2012 camaro Join Date: Feb 2012
no, it pretty much is a waste. what's in, and what isn't, in your gas is regulated by the feds. there are already plenty of detergents in there. it isn't the 1960's anymore. gas, oil.....everything, has come a long way. the fluids you buy today are 1000x better than what you were using just a decade or two ago. It never ceases to amaze me how much money people waste on stuff like this, 3k oil changes and so forth. |
02-15-2014, 08:26 PM | #13 |
agreed. the days of water in gas are over. not many people realize this, but when the truck shows up to deliver gas they check to see how much, if any, water is in the tank. that's what they're doing when you see them put the long stick in the tank. they aren't measuring how much fuel is there. if they find more than (I think) and inch of water, then they can't deliver gas until the station does something about it. if they do, they will have to answer to the EPA, consumer protection agency, and weights and measures.
02-15-2014, 08:30 PM | #14 | |
