01-19-2014, 01:32 PM | #1 |
Drives: '13 Hot Wheels SS Join Date: Aug 2012
Pros/cons buying pre modded car
So I'm looking to buy a new camaro but I want one with stuff already done to it, what are the benefits and disadvantages to buying a camaro that's already been modded.
01-19-2014, 02:21 PM | #2 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Disavantage: It will always be somebody elses Camaro.
01-19-2014, 02:34 PM | #3 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
My biggest concern would be if the mods were done by someone who knew what they were doing. Bolt-ons maybe not so much but of any engine internal mods like a cam I would be cautious.
01-19-2014, 03:07 PM | #4 |
If you like what has been done to it, go for it. Bolt on's shouldn't be a problem, but as has been said, if there are internal mods, make damn sure you know what you are getting and who built it. If it's the owner or a shop you have never heard of, I'd real cautious unless you know there skills are good. If the car was built by a reputable shop, you'll be better off. In any case, I'd contact the builder and talk to them. If you do buy a modded car, be prepared, as anything that happens is now on you. I know of one person that bought a heavily modded car and 4 weeks later is having to put an engine in it. He was told there were absolutely no problems with the car.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
01-19-2014, 07:07 PM | #5 |
Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
It's A lot cheaper to buy one already modded if that's what you want.
01-20-2014, 01:20 PM | #6 |
Echale Gas [COTW 3/10/14]
Drives: 2010 Camaro SS/RS Supercharged Join Date: Aug 2010
Cons: modded cars depending on who did them can be a ticking bomb
Pros: almost always you get .50 or .25 cents to the dollar they spent in mods. I would go for a modded car, thats what i bought and im almost at 85,000 miles with no issues at all
Kenne Bell 502 rwhp/ 471 rwtq at 9psi (daily driver...for now) Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers |
01-20-2014, 01:30 PM | #7 |
Drives: Camaro Lighting Experts Join Date: Feb 2012
It really depends on the mods, but I'd say go for it.
As long as the current owner provides you with all of the needed information about the mods and the car's history. Nick C.
01-21-2014, 11:16 PM | #8 |
Chain Blue Lightning
Drives: 2010 IBM Camaro SS Join Date: Oct 2013
Pro: you don't have to spend cash on doing the mod yourself
Con: If you don't like the mod your spending money on something you don't like Pro: If you don't like the mod you can remove it and replace with OEM. Then sell the parts to someone else! Con: you won't get much for a used mod Pro: The bad mods make the car less costly Con: The good mods make it more costly Pro: The mods may help when it comes time to resell the car Con: The mods may not help when it comes time to resell the car In the end it is either what you want or it isn't. My choice would be research it and test drive if your comfortable then buy it if it makes you nervous then look around more. Good Luck
My Vehicles 1968 RS Camaro 1978 RS Camaro 1983 VH Commodore 1996 VS Commodore 2005 WL Statesman 2010 SS Camaro |
01-21-2014, 11:25 PM | #9 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2013
Pros...You don't have to spend the money on those mods now
Cons...The car was modded for a reason; to get beat on. I personally like to buy stock, and if budget allows it I buy brand new! This way I know what was done, when it was done, and who it was done by. Not to mention youll have all(if any) warranty info on the parts
01-21-2014, 11:29 PM | #10 |
Drives: Boss 302 Join Date: Mar 2013
Con: You don't get to build your car and step back and go yeah I built it.
01-23-2014, 09:03 AM | #11 |
Drives: 2014 1LS BRM Join Date: Jan 2014
That is a huge one in my opinion, I don't like to buy someone's project. I did it with my gti, but the previous owner was the top mechanic at my dad's shop. So I knew the car was built correctly and that he did not try and go cheap on parts. He did put a lot of the car back to stock when I got it so I got to play around with it a little. (Being in Cali he had to, to even come close to passing smog)
