01-15-2014, 09:07 PM | #1 |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Solo Mach XL with J-Pipes cat-back
Since I just had the Solo Hi Flow Cats installed this past Friday, I started to look at cat-backs to complete my exhaust system overhaul....decided to go with Solo for this too. Just ordered the Mach XL with J-Pipes.
Anyone else go with this system? |
01-15-2014, 09:42 PM | #2 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
ive always wondered the purpose of J Pipes.....I have seen them on imports for sound...would this be the same case with our vehicles?
01-15-2014, 09:58 PM | #3 |
01-15-2014, 11:32 PM | #4 |
the jpipes are use to tune out the drone.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
01-15-2014, 11:44 PM | #5 |
Drives: 2011 Camaro 2ss Join Date: May 2013
Does anyone know if the npp exhaust when closed produces drone?
01-16-2014, 12:33 AM | #6 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
I love my Solo high flow cats and I think the sound and power is great. Quiet when cruising and a nice sound when on it. I would go with the Solo catback myself, but, I am curious to know how much louder it will be. And yes, the J-pipes are to reduce drone and can be adjusted to your liking. Keep us posted with this mod.
01-16-2014, 08:40 PM | #7 | |
Drives: 2010 2SS/RS A6 CGM Join Date: Jul 2010
01-16-2014, 09:17 PM | #8 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
01-16-2014, 11:14 PM | #9 | |
01-17-2014, 12:48 AM | #10 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
I got the magnaflow resonated x pipe , solo hiflo cats and solo axelback. Welded open the butterfly valves that came on my vert and it sounds great great when cruising loud when you get on it im going to swap my shorties for 2 inch longtubes and no cats see what it sounds like. Might need to add some mufflers will see
Ported intake manifold and throttle body kooks 2" headers no cats
01-17-2014, 07:40 AM | #11 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
I have the Solo catback with SW long tubs & HFC's. The exhaust is still quiet unless you're on it or on cold start. I will be doing a cat delete this spring, if this doesn't wake up the exhaust a little more I will be forced to scrap this setup and go with a full SW setup. Solo is a great exhaust the, excellent build quality and finish, just a tad too quiet for my tastes.
01-17-2014, 09:54 AM | #12 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
It'll rock after the cat delete.
Another 1 of 371 '12 T3 LS3 M6's built.
01-17-2014, 11:15 AM | #13 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Yes I have that exhaust since they first came out before the j-pipes. I added the j-pipes when they were introduced. Love the system, its holding up real well with no issues. The j-pipes work great to tune out the drone. My car was actually real quiet in the car on highway and around town. Only issue I have now is because I added a cam and blower and it is real loud inside the car. Need to find a solution or it might be time for something else.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
01-17-2014, 12:35 PM | #14 | |
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06 |
