dave@hennessey
Old 01-02-2014, 12:15 AM   #1
Mobyd
Mobyd's Avatar
Drives: 2010 White 2SS/RS,01 F150 SuperCrew
how to turn off A/C, Defroster switch light
2010 2ss - theres a light always on on A/C buttons its switchable to diffrent modes (panels only, panel and feet etc.. Sometime it is not there sometime you cant turn it off completely how can it be done?
Mobyd is offline   Reply With Quote
Old 01-02-2014, 12:18 AM   #2
eymang
eymang's Avatar
Drives: 2011 2SS/RS & 1991 Vert
You should be able to toggle it off/on
eymang is offline   Reply With Quote
Old 01-02-2014, 12:22 AM   #3
Bmatth1162
Bmatth1162's Avatar
Drives: 2011 1SS/RS LS3
Turn the fan knob (the left knob) all the way off - it should completely shut down the A/C system and turn the light off...
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways
Bmatth1162 is offline   Reply With Quote
Old 01-02-2014, 12:25 AM   #4
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Press the "snowflake"- light turns- A/C is on.
Press the "snowflake"- Light goes out- A/C is off.
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 01-02-2014, 12:25 AM   #5
Mobyd
Mobyd's Avatar
yes but even fan toggle turned to Off, there a light either on the A/C side or Defroster side which wont go away means giving little heat or cold (depends on the temprature toggle setting) is always ON.
Old 01-02-2014, 12:29 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Who the hell looks at the tiny little light on the AC knob?
Drive the car and enjoy. Keep your eyes on the road. lol
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 01-02-2014, 12:30 AM   #7
Mobyd
Mobyd's Avatar
means air cannot be shut down completly it is coming to either vents or windsheild after fan toggle is turn all the way to Off
Old 01-02-2014, 12:32 AM   #8
The Blue Angel
With the fan speed turned all the way off. Press the defroster that is lighted. The light should go out. The press the "snowflake"(A/C). It should be green. For heat, press the "snowflake". Light should go out. Hopefully that helps you out.
A Road Warrior
Old 01-02-2014, 12:36 AM   #9
Mobyd
Mobyd's Avatar
Thank You
Old 01-02-2014, 04:30 PM   #10
ChrisBlair
Buick 455 Fan
you can also turn the fan all the way to the left and then select an air path (left knob). This reverts to 'vent' and shuts off the a/c or defroster. You can then select 'recirculate' (right knob) to shut off the vent.
Old 01-02-2014, 06:01 PM   #11
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Lmao !!!
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 01-02-2014, 06:40 PM   #12
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
slick rick is offline   Reply With Quote
Old 01-02-2014, 07:16 PM   #13
BlueSteele
BlueSteele's Avatar
Drives: 2010 Camaro
I saw on here once (a while back) that holding down the button that is lit for 5+ seconds will turn the light off as long as the fan speed is off. Haven't tried it personally though.
BlueSteele is offline   Reply With Quote
Old 01-02-2014, 10:43 PM   #14
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Okay...heres the thing...even though you might not have turned the A/C on yourself, the DEFROST system will still activate the A/C compressor as the A/C system drastically helps/aids in speeding up the defrost/moisture removal process.
If you're select is set to WINDSHIELD or WINDSHIELD & FLOOR, no matter what the heat setting is or even if the A/C button is ON or NOT, the compressor will still kick on and off periodically. You can even feel it kick on and off (at least with an LS3 manual car) when you are IN gear and engine braking to slow down. Ive actually noticed that the compressor drag aids in slowing the car down faster.
After the inside of my car is warm and the windows are defrosted, I put my HVAC selector on FEET or FACE & FEET and the compressor will NOT turn off and on since the HVAC is no longer in defrost mode. You might even save the ever most littlest bit of gas if you do this too.
Try it yourself if you're skeptical or dont believe me. I've tried and compared myself over the last 1.5 years and I can definitely feel and notice the difference.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
