Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 12-23-2013, 11:44 PM   #1
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
19" clear brembos?
Will a 19" rim clear the brembos on a SS?
franknbeans is offline   Reply With Quote
Old 12-23-2013, 11:50 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Stock no. Some say you need a spacer and it'll work. Maybe someone who's done it will chime in.
Aftermarket yes depending on wheel specs
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 12-23-2013, 11:54 PM   #3
sswiss3000
sswiss3000's Avatar
Drives: 2012 Camaro 2SS Vert, L99
The 19 inch OEM Rims will fit the SS. All you need is 2 of the smallest spacers you can find (ie. 1/4inch or so) on the front wheels to clear the calipers. No need to remove the weights on the front pads either. Now you will hear tons of people telling you that spacers are no good and I would agree with them if you want to use bigger spacers, but I have been using my very small spacers for several years now and know of several other members that have done the same with no issues. I would not suggest doing it if you want to use them for racing purposes.
sswiss3000 is offline   Reply With Quote
Old 12-24-2013, 10:29 AM   #4
franknbeans
Whipped
Drives: 2010 CAMARO
Guess I should of said aftermarket. I'm looking to either
A. Get another set of rear rims for track days (rear 20" for the front)
or
B. Get a set of cheaper 19" rims since there's more tire choices.
Old 12-24-2013, 10:33 AM   #5
sswiss3000
sswiss3000's Avatar
or
Franknbeans, well in that case you have to either be very specific on which 19inch aftermarket rims you want, and try to find someone that tried these specific rims or simply go with a set of 20's that have the correct offset.
As you can see in my pictures, 19's are very tight with the Brembos and depending on their design could easily be too tight.
Old 12-24-2013, 12:43 PM   #6
SSeniorMoment
Drives: 2010 2SS/RS LS3 A6 IOM
I've been thinking about 19s also and Forgester F14 and TSW Nurgenberging <sp?> wheels came up in the discussion. I'm very much on the learning curve with wheels and suspensions.
I'm thinking Pfadt conversion to accept their ZL1 spec sways for a track/road set up. Currently have Foose 20x8.5 (27#s) front and 20x10 (29#s) rear, 19" 22#-24# wheels sound good if it can be done.
SSeniorMoment is offline   Reply With Quote
Old 12-24-2013, 12:50 PM   #7
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
19" Forgestars will definitely fit with the right offsets...www.dv8motoring.com, Tony can set you up with them
So Cal Camaro is offline   Reply With Quote
Old 12-24-2013, 05:17 PM   #8
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
Stock 19" clears w/o spacers on rears.
its a syn is offline   Reply With Quote
Old 12-24-2013, 10:50 PM   #9
franknbeans
Whipped
Drives: 2010 CAMARO
thanks guys. I really just looking for a full track day set of rims/tires. I love the black Forgestars I have on my ride now. (sig pic)
Old 08-12-2020, 09:12 AM   #10
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
Bump interested if the SS brembos will clear my lexani R3s 19x8.5 or will I need a spacer
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
