Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 12-06-2013, 06:14 AM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
Axle install ?
Is there any write up on on here for installing axles? Did a search and could not come up with much. Thanks for any info.
Craig B is offline   Reply With Quote
Old 12-06-2013, 04:41 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
Sure, here it is by our friends at Spohn
(Spohn install click here)
Driveshaftshop is offline   Reply With Quote
Old 12-06-2013, 06:49 PM   #3
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks for the link.
Old 12-07-2013, 08:37 AM   #4
GFORCE1320
Drives: 05 GTO
Did you get them in Craig? It's not too bad of a job. The inner stubs should pop right out like I said on the phone. They can be a little stubborn sometimes but usually come right out.
I'll have to make a nice set of install instructions to include with them.
Let us know how you like them once they are installed.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 12-07-2013, 01:09 PM   #5
Craig B
Craig B's Avatar
Drives: 2013 1LE
Thanks
Chris
Yes there in. It's an easy swap. Going to go for a quick spin today. Thanks.
Old 12-16-2013, 07:35 PM   #6
GFORCE1320
Drives: 05 GTO
What's the verdict?
Old 12-16-2013, 08:04 PM   #7
Craig B
Craig B's Avatar
Drives: 2013 1LE
What's the verdict?
There in !!! Only drove about 10 miles with them, so far everything is good. Had to shim up on the Pfadt drag bar, it was rubbing on the axle. Also let me know when these will be available gun drilled. They weight a ton
Old 12-16-2013, 08:23 PM   #8
GFORCE1320
Drives: 05 GTO
Yes, they are pretty beefy LOL
We won't be offering any gun drilled axles, gun drilling them makes them lighter but also weaker.
Old 12-16-2013, 09:47 PM   #9
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Agreed that weight hurts but there is a lot of other places I'd look before worrying about extra weight that holding the wheels to the ground on launch.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 01-10-2014, 12:08 PM   #10
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Had a stock diff fully built up. Im installing GFORCE axles right now, but Im not sure if the axle is in all the way. It sound like it is bottoming out, but the clip doesnt seem to catching anything. I can easily pull the axle out. Ive given it a good push and it hasnt budged. What do you guys think?
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 01-10-2014, 12:11 PM   #11
GFORCE1320
Drives: 05 GTO
That's not all the way in, it should slide in clear up to where the stub almost hits the housing.
Old 01-10-2014, 12:13 PM   #12
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Ok, will continue to work on it! Just didnt want to leave it like that. Thanks for the help!
Old 01-10-2014, 12:42 PM   #13
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Are they typically difficult to go in? I can get both sides in the same amount. I dont think it matters but I have a TruTrac in right now. Maybe the builder didnt line something up?
Old 01-10-2014, 02:53 PM   #14
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I remember when I was putting my stock axles back in, I had troubles like this. I lubed up the axle spline very generously, especially right around that ring. Before installing, try to center the ring in the axle groove evenly. I put the gap in the ring at the 6 o'clock position when pushing the axles in. And as a last ditch effort, I had a 4"x4" block of wood that held on the outboard edge of the axle and smacked it good with a 4 lb. dead blow hammer!!!! They certainly went in after that!!!! No....not a single-person job.
In comparison, I helped a buddy install a new rear end in his car a few months after mine, and I just had to wiggle the axle back-n-forth a little bit, give it a shove, and it popped right in!!!! Yeah, I was kinda pissed!!!!
blazzin1 is offline   Reply With Quote
