Old 11-10-2013, 09:02 AM   #1
Camaronutt
Drives: 68 Camaro--2009 Corvette
Rear Gears ?
Does any one make rear gears around maybe 4:56 or so that will fit in the 1Le diff? Sure would be nice for the drag strip!
Camaronutt is offline   Reply With Quote
Old 11-10-2013, 04:26 PM   #2
Boydr12
Drives: 2012 Camaro RS, 2013 Camaro 2SS 1LE
The 1LE is a track oriented car so I would think about going with something else.
Boydr12 is offline   Reply With Quote
Old 11-10-2013, 04:42 PM   #3
Msmall143
Msmall143's Avatar
Drives: Camaro
Thanks captain obvious! hence why mods exist!
The 1le differential is part 22806794. I'd start by looking at what other gm cars its in. It will help broaden your search past "1le rear gear"
Msmall143 is offline   Reply With Quote
Old 11-10-2013, 07:19 PM   #4
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Anything that fits in the 2010+ SS will fit in the 1LE.
Dropspeed is offline   Reply With Quote
Old 11-10-2013, 08:54 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I think, perhaps, he was alluding to the fact that there's a lot of stuff on the 1LE not suited to a drag strip, and possibly wasted money...if the drag strip is the only goal.
Old 11-10-2013, 08:58 PM   #6
Msmall143
Msmall143's Avatar
Drives: Camaro
Maybe, but what car from the factory is suited for a drag strip? All need mods to make ideal. Just didn't see what the point of even responding was to point out it has a track package, and a big part of the track package setup is gearing.
And to be honest I think these 1le's get to much of a "track only" wrap. The wheels and tires were worth the 3500, the rest was just icing on the cake!
Old 11-10-2013, 09:40 PM   #7
Fraxum
Fraxum's Avatar
I think though the standard 1LE gearing closely resembles the first two gears of the standard LS3 SS with the 3.42 gears.
I am not able so far to beat my best 60' LS3 '11 SS times on Pirellis with my NT555R drag radials on my 1LE. I am sure part of it is my technique, but I wonder if the bigger front sway bar and stiffer shocks are hurting weight transfer and hence the 60'.
Sill my 1LE is running good times considering the 60' it is getting. But 11's will be tough.
A couple of stock 1LEs have run 112 mph quarters, but struggle to get into the 12s. No standard LS3 SSes have run 112. This may be because the standard SS requires a shift to fourth to get over 110 mph.
Old 11-10-2013, 10:16 PM   #8
Msmall143
Msmall143's Avatar
Drives: Camaro
Not arguing with you, but can someone confirm this?
Old 11-11-2013, 03:35 AM   #9
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Right. Like the half shafts could snap as they have for others on this site.
Sent from my iPad using Tapatalk HD
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 11-11-2013, 06:26 AM   #10
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
2013 Mustang 5.0 with 3.73s
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 11-11-2013, 06:51 AM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Richmond makes a 4.33 that will work.
Apex Motorsports is offline   Reply With Quote
Old 11-11-2013, 08:11 AM   #12
davidcroft
davidcroft's Avatar
I'll confirm this!
Old 11-11-2013, 09:16 AM   #13
Dropspeed
Dropspeed's Avatar
No worries as you should. The rear end is 100% standard 2010+ Camaro SS/M6 with the only diff being the 3.91 ring and pinion.
The ZL1 has a unique rear end
The Z/28 is similar to the standard SS rear end with the addition Torsen Helical diff and different cover for the rear diff cooling system.
Old 11-11-2013, 09:19 AM   #14
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
just buy a complete diff and sell me yours
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
