10-19-2013, 06:58 PM | #1 |
Drives: 2011 Camaro V6 Join Date: Jun 2013
Home Painting Question
I just purchased a spoiler for my CGM car - it is going to go great, except for the fact that it is a blue spoiler!
I am planning on painting it myself. Sand it, prime it, paint a few coats with spray touch up paint, a couple of clear coats, finished. It sounds perfectly easy. So, what should I be looking out for as I am working and I am foolish to try it at home? Anyone do something like this successfully? |
10-19-2013, 07:28 PM | #2 |
Surface prep is the key. Make sure you have a smooth primer coat and that it's absolutely clean before painting the color coat. Spray your color coats light to medium. You can always add another coat, but a heavy coat that runs is a disaster. Same with the clear coat. I always spray lots of clear since I wet sand most of it off to get a smooth finish to polish. If you sand, go easy so you don't cut through the clear, and remember, the paint will be thinner along the edges. Take your time and you should be fine. I would consider getting your paint from here.
http://www.automotivetouchup.com/
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
10-19-2013, 08:41 PM | #3 |
Thanks. Do you wet sand the colors coats as well or just wet sand between clear coats. I plan on spraying outside and I am concerned about dust in the paint.
I figure worst case I goof it up and have to have it sprayed by a body shop. I'd rather try it myself first. |
10-19-2013, 09:10 PM | #4 | |
Reaper Crew
Drives: Blown 2010 Camaro SS Join Date: Aug 2012
2010 Camaro SS SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP Pedders XA Coilovers |
10-19-2013, 10:13 PM | #5 | |
Thanks for the advice. |
