10-19-2013, 04:48 PM | #1 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
Tackling ROTO-FAB CAI &
With the help of a friend we plan on installing the ROTO-FAB CAI, Big Gulp & WW relocation tomorrow afternoon. Doesn't look like rocket science. Anything i should look out for? Read plenty of the install threads here already. Watched the videos and have the written instructions. Couldn't find a video on the WW.
10-20-2013, 06:26 PM | #2 |
All installed and now have an engine light. everything seems to be connected correctly. any ideas?
10-20-2013, 07:43 PM | #3 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
10-20-2013, 08:00 PM | #4 |
10-20-2013, 08:00 PM | #5 |
Drives: 2000 Camaro SS 2013 ZL1 Camaro Join Date: Jul 2012
Also check the fitting on the bottom of the tube. I think i remember needing tape and make sure its all the way in there.
10-21-2013, 05:37 PM | #6 |
Drives: Chevys at the limit Join Date: Nov 2010
Check all connections and fittings for leaks etc. You should not have a CEL unless something is loose or disconnected.
Best regards, Tyler 888-308-6007 |
10-22-2013, 06:51 AM | #7 |
Drives: formerly a AGM ZL1 (sold) Join Date: Jan 2010
My car threw a CEL on first start after installing my roto-fab also. I went over everything and it was all connected correctly. I just cleared the code and it never came on again.
2013 Ashen gray ZL1 M6 with Roto-fab, Vmax TB, Pfadt headers, 10% pulley, JRE tuned. 11.459 @125mph. 566hp/517tq. Sold due to not enough seat belts. FML.
10-22-2013, 10:23 AM | #8 |
Okay disconnected the connections for the breather canister & map sensor. I think the map sensor connection wasn't good. CEL Gone..... Now noticed 2 other issues one with the WW relocate & Big Gulp. I"ll start 2 other threads later today. Man I hate doing something for the first time.
WW relocate http://www.camaro5.com/forums/showthread.php?t=324414 Big Gulp http://www.camaro5.com/forums/showthread.php?t=324415 Last edited by rvnmaniac; 10-22-2013 at 02:50 PM. |
10-22-2013, 10:04 PM | #9 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Did you or the OP turn on the ignition while the MAF was unplugged? Maybe to listen to the radio? That would set a code.
Bryan 2018 ZL1 M6
10-23-2013, 08:48 AM | #10 |
If turning the car on, but not starting it will set a code then that might have been my problem. After installing the WW relocate i turned the car on to make sure it was operating correctly, but never started the car. The OEM Air filter and housing was disconnected at the time. Makes installing the WW relocate reservoir easier.
