dave@hennessey
Old 10-15-2013, 05:28 PM   #1
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Forced Induction with Cutouts - Any Issues?
I am considering adding cutouts on my exhaust just for occasional fun, but want to know if anyone running boost and cutouts have had any issues.
I know of one other guy on the forum that I have corresponded with that said he gets a "backfire" when deceleration occurs (he has cutouts) but did not have this issue when he was just running a cam and headers. The backfire started after adding forced induction.
I asked him if he had to do it all over again if he would still add them and he basically said it was great before adding boost, but now it was bad enough that he intends to change up his exhaust system.
I am running a Maggie set at 10 psi and full Kooks headers/cats/mufflers, etc. My shop will install a set of cutouts for ~ $800.
I would like to hear what you guys have to say first.
Thanks!
Biggfoot
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 10-15-2013, 05:57 PM   #2
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
from what i heard, there were heat issues due to the boost and exhaust runs hotter...most people complained that motors went bad due to heat, anything running approx 600rwhp, i would prob not advise it..imo
mikepage0007 is offline   Reply With Quote
Old 10-15-2013, 06:00 PM   #3
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
No issues at all. Just dumping exhaust earlier
jrpxxii is offline   Reply With Quote
Old 10-15-2013, 06:15 PM   #4
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
I had no issues when I was running my Whipple & DMH combo, love that sound!
BrainleSS is offline   Reply With Quote
Old 10-15-2013, 06:20 PM   #5
rdblan2
Drives: 2SS RS
I have QTPs with the whipple. It's loud as shit when you open them, like Earth shaking, life changing loud. I don't run them open often though.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 10-16-2013, 01:18 AM   #6
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
No issues whatsoever!
Noweeds (FI) since 2011, currently @ 15# boost - all is well!
Boost seems to drop a bit, but it's difficult to read the gauge when going flat-out with diverters open
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 10-16-2013, 04:30 PM   #7
BiggFoot
BiggFoot's Avatar
I appreciate the replies.
Blower Cam
RPM Level VII
TR6060
Old 10-16-2013, 04:43 PM   #8
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
They sound great open, but at the track my car slows down over a second, it feels like it loses boost and runs like crap.
casper sc/1ss/rs is offline   Reply With Quote
Old 10-16-2013, 05:19 PM   #9
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
I have a centri and it seems less responsive and shifts tend to lag on part throttle. I just don't like the feel of them open. I haven't gone WOT with them open after the blower. Also I was told by my tuner that I dropped 8 HP on the dyno w them open
DarkCry956 is offline   Reply With Quote
Old 10-16-2013, 05:20 PM   #10
DarkCry956
DarkCry956's Avatar
Oh I forgot to say I love cruising with them open they're awesome
Old 10-16-2013, 06:14 PM   #11
rdblan2
Drives: 2SS RS
I should also mention my car is noticeably sluggier from a stop with them open. This may be a good thing if you don't have traction on street tires.
Old 10-16-2013, 07:51 PM   #12
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I cut the same 60 and same ET open or closed. Dyno #'s don't change open or closed.
Nitroman28 is offline   Reply With Quote
Old 10-16-2013, 09:22 PM   #13
rdblan2
Drives: 2SS RS
The numbers may not change, I just notice the car is slower out of the hole with them open.
Old 10-16-2013, 10:04 PM   #14
2L82RUN
Drives: ABM SS/RS
Whipple with DMH cutouts. No cats. Dyno #'s don't change much open or closed. +\- 3hp.
Have a friend with same setup running hi flow cats and he ran into heat issues when running with them open. Melted some shit. I haven't had that issue but not running cats either.
2L82RUN is offline   Reply With Quote
