09-10-2013, 02:51 AM | #1 |
Drives: 2011 2LT RS Synergy Green Join Date: Jun 2013
Oil Life System
For oil changes do you rely on the car's oil life system to tell you when to change oil or do you follow a standard 3,000/5,000 mile oil change interval? Thanks!
09-10-2013, 02:58 AM | #2 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
i still follow the 3k/5k regimen.
09-10-2013, 07:57 AM | #3 |
Drives: 2014 Summit White 2SS/RS M6 Join Date: Aug 2012
i go by what chevy put on the car. (oil meter)
09-10-2013, 08:04 AM | #4 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Every 5k here on all my cars.
09-10-2013, 08:17 AM | #5 |
Let's go Rangers!
With an LLT, DO NOT follow the DIC!
Here is my statndard post to V6 (in particular LLT engines) oil posts when asked about the DIC or questions about oil changes: Newer 2011 and those that had the ECM flashed the OLM is now pretty much mileage based and will zero out at right around 5K, regardless of the driving condition. My guess is they did this because of the LLT engine/timing chain issues and people letting the OLM zero out. As with all V6's (especially the LLT), I suggest the following: 1- Check your oil frequently; I do mine at every fill up 2- IGNORE the OLM 3- Oil changes: Conventional <= 3K Synthetic (Preferred) <= 5K. I use Mobil 1 and change at 4K These little steps can help save your V6 from the dreaded timing chain/oil loss issues Last edited by nyrfan; 09-10-2013 at 08:30 AM. |
09-10-2013, 08:17 AM | #6 |
ALWAYS-N-BOOST
oil meter, but I check the levels regulary...the meter tells you the oil life, dosent tell you how much is in there, and theses cars DRINK oil
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
09-10-2013, 09:29 AM | #7 |
I'm on a 7,500 mile oil change schedule but I check my oil for level and color once a week (or so).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
09-10-2013, 09:32 AM | #8 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
I do around 7k. but i do check my oil every couple of weeks
09-10-2013, 09:36 AM | #9 |
mine consumes very little, if any oil. and it gets changed at 3000 miles.
i dont trust the "oil life" meter at all. |
09-10-2013, 09:50 AM | #10 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I go by the oil meter, but I change the oild when the oil meter drops below %50 life left. Typically it results in changing the oil every 4,000 miles or so.
Did that on my 2011 2SS/RS and also on my current 2013 ZL1. |
09-10-2013, 09:52 AM | #11 |
Drives: 2012 Camaro 2SS/RS Convertible, IBM Join Date: Jun 2012
Does Cadillac still make the V8 "Northstar" engine, think it was 4.6L. Anyways GM stated that a quart per 1,000 miles was normal for that engine. Really upset a lot of people, almost doing a rolling oil change.
Someone on one of these forums with a V6 has been doing an extensive OLM test with Blackstone Labs. He has changed the oil at 9k and Blackstone told him to try for 10k next time as the oil life integrity was still good. |
09-10-2013, 10:25 AM | #12 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
I use the meter...at 50% I change it...I built me a set of ramps from 2 ten foot 2x12's...I cut each one at 4' 3' 2' 1'....nailed them together...it rises 1.5" every foot for a total of 6"s...makes changing my own oil safe and simple
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
09-10-2013, 10:32 AM | #13 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I change mine around 50% on the oil life monitor. Never had an issue with oil level on this car or my 2010 with the LLT. Every time this comes up and people say their car uses excessive oil I ask what break in procedure was used, by the book or like engine builders say running it hard. So far I have not gotten anyone to answer.
The Bird is the word! |
09-10-2013, 10:39 AM | #14 |
I use ac delco filters and Mobil one oil....and save all my receipts....and my son-in-law owns a auto repair shop....I'm covered every way you can be
