08-20-2013, 11:35 PM | #1 |
Drives: 2010 camaro 2ss Join Date: Feb 2011
Which vvt cam ?
Which is the vvt cam available that can be used without a torque converter. Not looking for an extreme cam.
I want to keep vvt. thanks
2010 2ss L99
Mods: ADM race intake, ADM scoop w/ washer bottle, SLP long tube headers, SLP 25% UDP, SLP Loud Mouth 2 exhaust, Vmax TB, BER intake manifold,3.45 gears, MSD wires, SLP 160 t-stat, SLP Springs, EFI live tune by Redline Motorsports |
08-20-2013, 11:46 PM | #2 |
Drives: 2013 SS Join Date: May 2013
Speak with Rhino79 he knows his VVT.
Glad I could help.
08-20-2013, 11:48 PM | #3 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
You do realize that the Torque Converter has to do the your Automatic Transmission, right? It has no bearing on your VVT Cam.
Unless I am not understanding the question. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
08-20-2013, 11:50 PM | #4 |
Some wild cams require a converter to work properly, without on it will die on you at a light or it'll fight your foot when you break.
08-20-2013, 11:50 PM | #5 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
OP, check with Rino or TSP. Both are the VVT guru's on here.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
08-21-2013, 12:00 AM | #6 |
Ahhhhhhhh, yea, misunderstood. Go figure.
Yea, Rhino or Jason @ TSP. T.
08-21-2013, 12:17 AM | #7 |
Please come back and update this thread after talking with them. I would like to know what you find out. I don't want to change the converter either but would be interested in swapping cams.
08-21-2013, 12:22 AM | #8 |
Drives: 2012 Camaro SS Best Run - 10.93@125 Join Date: Feb 2012
The converter swap is a sweet mod. I have a 3800 stall circle d multi disc in mine. It's a sweet machine with a different converter.
08-21-2013, 12:22 AM | #9 |
Drives: 2SS RS Join Date: Sep 2012
I would most likely call rhino or Tsp. What I am sure of though is you can run TSP vvt1 cam without a converter and I bet you can get away with their vvt 2 cam as well but it won't be as civil
08-21-2013, 12:25 AM | #10 |
Drag racing is not my thing though. Running hard through the mountains and road course is more like it for me. 90% of the time is daily driving duties.
08-21-2013, 12:58 AM | #11 | |
But I do understand what you are say
08-21-2013, 01:53 AM | #12 |
+1. It will compliment your current mods. You will want to do a larger trans cooler. Which I would suggest to anyone, aftermarket converter or not. My temps creep just past 180 on a 116* day in the blazing az heat. That is when I decide to drive it. Which isn't often.
08-21-2013, 05:36 AM | #13 |
Drives: 2011 L99 Camaro Join Date: Mar 2012
I have the Texas Speed VVT-1 without the converter. The cam made 70 rwhp with the ATI pulley. Depending on your tune, the cam will idle steady and take off without lurking. It has a nice mild lope with a little shake of the car. Now, the VVT-2 could be a little different without the aftermarket converter. PM me if you like.
08-21-2013, 07:23 AM | #14 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
That's what I was going to say was the vvt1...yeah or talk to rhino79. If you mainly do curvy roads vs drag racing, you don't want a high stall. Stock converter or maybe a 3000 stall single disk at most. You wanna drag race though...more stall and a triple is the only way. If redline is doing and will continue to do your tuning...you should put heart in their cam selection. You want your tuner to understand what they are working with. There aren't many out there that 'get' VVT.
-John S.
