TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 08-04-2013, 11:19 PM   #1
bigwayne3000
Drives: 2011 Camaro LS
65,000 miles too late for a catch can?
Is it too late to install a catch can onto an LS? My car has a little over 65k miles on it and I was thinking of adding a catch can but not sure if it's worth it now or if it's a case of better late than never?
bigwayne3000 is offline   Reply With Quote
Old 08-04-2013, 11:21 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Better late than never. Btw, I recommend an elite catch can. You'll have it soon as opposed to the massive wait for the rx one
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 08-04-2013, 11:27 PM   #3
bigwayne3000
Thanks man I appreciate it. I am planning to Seafoam my vaccum line and probably start using Techron in my gas so I thought a catch can will also be a wise decision.
Old 08-05-2013, 12:30 AM   #4
lscamaro
lscamaro's Avatar
Better late than never bud.
If you don't mind please post some impressions on how the car feels after the sea foam treatment
Old 08-05-2013, 04:09 PM   #5
hcso617
hcso617's Avatar
Drives: 15 SS 2SS RS 1LE Red Rock Metallic
As a new Camaro owner, I haven't had the opportunity to use it on a Camaro. I have used Sea Foam many times on other vehicles, especially the 3.8L jeep engine, and it worked as advertised. I wouldn't hesitate to use it on any vehicle.
2015 SS RS 2SS 1LE
Red Rock Metallic
hcso617 is offline   Reply With Quote
Old 08-05-2013, 09:18 PM   #6
SS_Killer
SS_Killer's Avatar
Drives: 2010LSM6
Never too late
[QUOTE=bigwayne3000;6858010]Is it too late to install a catch can onto an LS? My car has a little over 65k miles on it and I was thinking of adding a catch can but not sure if it's worth it now or if it's a case of better late than never?[/QUOTE
My LS has 104,000 mi and has never had a catch can. I installed (and later re-installed) "Black Ice". While doing this I used brake cleaner to de-oil the intake manifold and also looked at my intake valves. Yes, there is definite black buildup on each of them. Some more than others. I'll put on a catch can when I get around to it. Until then I'll Seafoam the intake before each oil change by bleeding it in through the PCV valve inlet.
Damn that stuff smoked up the garage! Next time it will be outside. Bonus though was that the exhaust leak at the exhaust manifold was pinpointed by the wisp of white smoke rising from the driver side manifold heat shield. The dealer was kind enough to fix it for me at a nice discount. The service writer likes me, saying that there is never any doubt what my car needs.
K&N Typhoon, Spohn sway bars, Pedders front radius rod bushes, BMR cradle bushing inserts, Enkei Tuning Raijins (20.7 lbs ea.), Dunlop Direzza Z1 Star Specs, -2 front camber, -1 rear.
SS_Killer is offline   Reply With Quote
Old 08-06-2013, 08:00 AM   #7
mpiersd
mpiersd's Avatar
Drives: ABM #2041
I second that. Ordered a RX can in mid may, just got it this past Friday. And I've seen better paint jobs on model cars built by 10 year olds.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
Old 08-07-2013, 12:29 PM   #8
Kid
Kid's Avatar
Drives: 2011 Camaro 2LT, 68 Camaro RS
Just installed my Elite can last week. Got it in 3 days, and it took all of 10 minutes to install witht eh included brakets. Even came with extra o rings for the can, and Pcv fittings in case you damage them.
I will say the instructions online were a little short, and they show the mount being installed between the engine cover pin and the braket. I mounted mine under the pin bracket where teh nut spins on so it would sit lower and not rub my cover.
2011 Black/Inferno 2LT. Inferno Brembos, MRT 2.0, Vararam, BBK LTs, RX Catch Can, VMAX ICE-olator, VMAX P/P Throttle Body, Monster clutch, MGW Shifter, OverKill Tuned.
Kid is offline   Reply With Quote
Old 08-07-2013, 10:36 PM   #9
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
That sucks to hear I have had my Rx can for about two years now and the paint looks fantastic . . .
ChadG is offline   Reply With Quote
Old 08-09-2013, 06:21 AM   #10
spyder
Drives: 2010 V6 | M6
+1 on elite cc
BBK 304 LT headers w/ coating | CAI Inc Intake w/ scoop | VMax Ice-olator | MRT v2 | Elite catch can | Trifecta Tune | Eagle halos | 20" Textured Black Forgestar F14s
- They call it the black panther.
2010 Camaro LLT (sold)
2008 Yamaha WR250X
2011 Nissan Armada 4WD Platinum
spyder is offline   Reply With Quote
Old 08-11-2013, 02:32 AM   #11
camarozzzz
Drives: Blue
Not to sound noob or anything...well this is a hardcore noob question...but what exactly is a catch can and what does it do? I have a 2011 1LT with 38000 miles on it. What does this mod do for me?
camarozzzz is offline   Reply With Quote
Old 08-11-2013, 08:22 AM   #12
Kid
Kid's Avatar
It basically acts as a barrier to stop oil from traveling from your pcv on your valve cover, into your intake where it can sludge up your valves. The oil gets trapped, or "caught", in the can.
