04-20-2013, 06:47 PM | #1 |
Drives: '11 2SS/RS A6 Join Date: Apr 2011
Spark plug help
Ok C5 family, need a little feedback. I prepped for my header install today (those O2 sensor plugs retaining pins and the dipstick are a PITA by the way)....anyway, I pulled all my plugs and this is what they look like. Sorry for the bad pic. The ones on the left are the passenger side and the bottom is the front cylinder. The last plug (top) on that side was wet with some unburnt fuel when I took it out. Any thoughts as to whats going on with this or, if it's an issue?
I have 5,200 miles, a CAI, and a ported TB. I have not tuned it yet but will once the headers go in.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can |
04-20-2013, 07:39 PM | #2 |
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova Join Date: Aug 2010
Im also waiting on some Kooks headers and cats i ordered to get here sometime in the middle of next week. They are already in route to me and will be doing this soon. I hope my plugs are not like that!!
Anyways.... Sorry bro but u cant really see anything wrong with any of the spark plugs from this pic. They all look pretty much the same. Any upclose pics?
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
04-20-2013, 07:41 PM | #3 |
Drives: 2010 Camaro L99 Join Date: Oct 2009
Needs tuned
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os |
04-20-2013, 07:45 PM | #4 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
needs a tune, Your engine is running rich... Also I'd install a oil catch can...
04-20-2013, 07:56 PM | #5 |
If i read the OP's #1 post it says that his car is still stock and is bearly getting it ready for when his headers arrive. So when he pulled out the spark plugs and wires that how his spark plu came out. No headers yet and he is still stock. Is this correct?
04-20-2013, 07:58 PM | #6 |
The car just probably runs rich on a stock tune to be on the safe side? Sorry i would like to know myself as i will be doing the same soon.
04-20-2013, 08:03 PM | #7 |
Yeah.....I'm thinking/hoping the tune will help. I think the CAI might be causing it to run a little rich. Here are a couple of closer shots. First one is the passenger side; next is the driver's. I just changed my plugs in my truck last weekend and they were black like this too but it has a 140,000 miles.
Just wondering if I should put a new set when I install the headers.....?
Performance Mods:
04-20-2013, 08:19 PM | #8 |
Yeah now u can see that the plug on the left is wet. Everyone including my tuner recommended that i switch out the spark plugs and wires to a new set. My car is a 2010 with only 12K on the clock. He recommended the NGK TR6 plugs at 40 degrees gap and i got some MSD wires part # 32819
04-20-2013, 08:24 PM | #9 |
Good feedback. I will run this by the tuner before I buy anything. Thanks!
Performance Mods:
04-20-2013, 08:25 PM | #10 |
No problem!!
04-21-2013, 12:58 AM | #11 |
Get a catch can! RX Made here!
2010 L99
04-21-2013, 03:18 AM | #12 |
Yes i also recommend for u to get a catch can. SC2150 i belive is a vendor on the forum. I got min from him and its awsome. You'll be supprised of just oil that can will catch.
04-21-2013, 04:08 AM | #13 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
04-21-2013, 06:58 AM | #14 | |
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can Last edited by RJT-SS; 04-21-2013 at 07:01 AM. Reason: typo |
