TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 03-24-2013, 03:09 AM   #1
jsd
jsd's Avatar
Drives: 2012 ZL 1 #370
Battery issue???
hey guys
last weekend i put my battery in my zl1 an was drive a little bit. now the winter is back again. today i deconnect the battery and see batterywater in the tube. From what comes this. my car hav 5000 km and thru the winter storage, the battery was charging in my appartment.
thanks
jsd is offline   Reply With Quote
Old 03-24-2013, 04:41 AM   #2
Geezerss
Geezerss
Geezerss's Avatar
Drives: 2011 ss2 droptop red/blkst hckyst
battery
wow, winter won't quit here either... you might be overcharging your batterry, fully charged it only needs about two amps to keep iy fully charged,, you might be cooking the plates.
good luck
Geezerss is offline   Reply With Quote
Old 03-24-2013, 02:33 PM   #3
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
What he said. You're over charging the battery and cooking the plates. You need to put it on a trickle charger and not on a full charge.
RoketRdr is offline   Reply With Quote
Old 03-24-2013, 02:59 PM   #4
jsd
jsd's Avatar
The battery was on a trickle charger. And the tube i let in the car. This issue comes first time now on the car. The volt meter shows all normal on the car.
Old 03-24-2013, 03:21 PM   #5
RoketRdr
RoketRdr's Avatar
You're probably good then. Check the tube in a couple of days to see if the battery is still bleeding. If so have a load test done on it.
