Old 02-15-2013, 01:17 PM   #1
Larz29
Larz29's Avatar
Drives: 2010 camaro ss LS3 cyber grey
Nitrous kit
Hey I just wanted to get some expert advice from all the gear heads in this thread.
So I have been kicking around the idea of putting the Cam and a Zex (or equivilent) nitrous kit in.
My bottom end is completely stock, and my ss LS3 has about 18k miles.
Would it be dangerous to go with a setup like this? Some say if tunned properly the ls3 can handle nitrous without a problem and be completely as reliable as a stock motor... Is this true? Would I really notice the difference in power from just installing a cam?
Larz29 is offline   Reply With Quote
Old 02-15-2013, 04:39 PM   #2
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i got a hsw kit its a lil on the old side. but if i was to buy a kit today nitrous outlet. those guys have helped me even tho i dont have their product. im a lg g6x3 cam and k&n intake , obx header and 2.5 magnaflow exhaust , with a hsw 90mm plate kit. this is things u will need or will want to make it safe. run br7ef plugs get either a progressive controller or a window switch. wide open throttle switch. Then either get 2 tunes 1 n/a and 1 nitrous. or get a lnc-2000 and pull timing. i got a lnc. its nice cause i can change things and its also a 2 step. but u can run a 200 shot with race fuel on the factory engine.
u will notice a big power diff on just a cam alone. my car gained about 70 rwhp from a cam alone.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 02-15-2013, 10:55 PM   #3
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Call Nitrous Outlet. Excellent info, products and customer service. Don't skimp on components. As long as everything is installed and functions correctly, you should have no issues other than traction. My aftermarket cats did blow out though.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 02-16-2013, 09:40 AM   #4
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
yep , nitrous outlet is top notch, great group of ppl there.
Old 02-16-2013, 01:33 PM   #5
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Nitrous Outlet set my system up to spray through a Maggie, they were a great group of people to work with. Highly recommended.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 02-16-2013, 01:56 PM   #6
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
To answer your question, yes you can run nitrous safely on a stock motor as long as you don't go crazy with anything over 125 shot and have a good system in place.
jrpxxii is offline   Reply With Quote
Old 02-16-2013, 02:01 PM   #7
Texas2SS
Vroom
Texas2SS's Avatar
Drives: Rarely
I run a 150hp shot on my stock motor. Loved every chance to spray I get. I have timing pulled and run 116 fuel with the nitrous.
LSX, Boost, 9", TH400
xxxxhp - xxxtrq
Texas2SS is offline   Reply With Quote
