01-30-2013, 09:05 PM | #1 |
Drives: 2012 45th SS Join Date: Jan 2012
Lost power after installing flowmaster
Seems like I lost low end power after installing a flowmaster axle back. I used the american thunder AMT Pro Series with the hush power mufflers. Not enough back pressure or to much?
Thanks |
01-30-2013, 09:40 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
At first I thought I lost some low end after putting on my outlaws but give them a bit of time for ecu to adjust. Mine are race mufflers so no restrictions, so might have.Now I really dont notice it.I do know when I added my resonated x pipe in for awhile it picked up bottom end.
01-30-2013, 10:12 PM | #3 |
Out Front!
A loss in back pressure, from what I've seen, takes power from the bottom end and move it up top. I've gone from no muffles, to having the exhaust dump after the headers.
You can feel the car pick up some more balls on the bottom end when I'd increase the back pressure with a more restrictive muffler. The opposite would happen if I freed up some back pressure by chopping the mufflers off.
B Troop, 3-17CAV - Out Front
02-08-2013, 06:59 PM | #4 |
I'm thinking about removing the resonators and see if I gain or loose bottom end.
02-08-2013, 08:21 PM | #5 |
I removed mine to see how loud the outlaws would be. Didnt notice any bottom end differences, only louder! I did notice a bottom end increase, or more throttle responce with a resonated x pipe but that made the car to muffled.might try regular x pipe.Maybe reason all catbacks have one
02-08-2013, 08:50 PM | #6 |
Drives: 2011 CAMARO SS Join Date: Jan 2011
I also need advice, just had a SLP loudmouth axle back put on my car yesterday with resonator deleted with X pipe. On mod i only have BBK cai that's about it on mod because of waranty
which i dont want to void. Been reading and hearing about back presure do you think i made the right choice, it's a lot louder now but the power i am not sure if it made a difference. |
02-08-2013, 09:15 PM | #7 | |
02-08-2013, 10:24 PM | #8 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Didn't you guys know? There is no such thing as back pressure. Turns out it was all just a myth from the carb days. Oh, and exhausts do not make any difference in performance at all...but that is only true for the 5th Gen Camaros. Every other car on the planet it does. Not this one tho. Your buttometers must all be way off...lol!!
02-08-2013, 11:13 PM | #9 | |
02-09-2013, 02:00 AM | #10 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Why didn't you add in that the REAR O2 sensors play a intrical part in tuning? Oh, I guess you learned your lesson on that one.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
02-09-2013, 02:07 AM | #11 | |
02-09-2013, 01:02 PM | #12 | |
Search Ninja
02-09-2013, 05:57 PM | #13 |
yes it's M6
02-09-2013, 06:04 PM | #14 |
"Hey, Mister; let me hold the dollar!"
JohnBoy and Billy Show |
