Old 11-04-2012, 09:46 PM   #1
midnighter
Drives: nothing
Arrow Funny square wheeled Ford F250 fail
Brought to you by MythBusters
midnighter is offline   Reply With Quote
Old 11-04-2012, 11:06 PM   #2
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I watched it today. That was a different version then what I saw. The one i saw was where all of the right rear lugs broke off.
Caddy
Caddyroger is offline   Reply With Quote
Old 11-04-2012, 11:07 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Well....that's one way to decrease the life of your suspension.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 11-04-2012, 11:14 PM   #4
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
What "myth" was this busting?
joeybsyc is offline   Reply With Quote
Old 11-04-2012, 11:20 PM   #5
midnighter
Drives: nothing
They wanted to see if it was true that with enough speed the square wheels would ride as smooth as round wheels. It didn't happen.
Old 11-04-2012, 11:22 PM   #6
midnighter
Drives: nothing
This clip is altered. I saw the show too and you are correct. I also saw the 2 cars stuck together from the fronts, that was interesting.
Old 11-04-2012, 11:24 PM   #7
Tysen
Tysen's Avatar
Drives: 2011 RJT 2SS/RS M6
I'd say that was successful, a Ford was damaged in the process.
"I'm a man who discovered the wheel, and built the Eiffel Tower out of metal and brawn! That's what kind of man I am." - Ron Burgundy
My build thread
Tysen is offline   Reply With Quote
Old 11-04-2012, 11:39 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
They did 2 tests. The first was with the faces of all 4 wheels aligned so that the flat face would be down on all the wheels at the same time. The other, which I believe this clip is from, had each wheel offset by 22.5 degrees.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
