10-13-2012, 02:57 AM | #1 |
Drives: Camaro SS 2010 M6 Join Date: Jul 2009
How reliable is the ZR1 MAP at reading boost?
I finally installed the ZR1 MAP sensor on a 2010 LS3 with a procharger p1sc-1 tuner kit (stage 1 up to my knowledge) and re-tuned the car. As far as power mods go, it is stock except for the procharger kit (ie. no intake manifold, no ported TB, no headers, no catback, no cutouts) and made 497rwhp/452rwtq at the dyno @ a reported ~5psi (ok, ok, it was more like 5.31 or something close to it) @ 6.5k rpm. the boost reported was increasing linearly from what I can remember seeing in the computer screen (give or take ~1.25psi @ 2k rpm, ~2.X psi @ 3k rpm, ~3.Xpsi @ 4k rpm, ~4.X psi @ 5k rpm, ~5.X psi @ 6k rpm from what I could oversee in the graphs at the dyno shop).
The reason I ask is because I have no idea what the pulley sent in the "kit" should be. I keep reading it is 5psi in some places, and 7 psi in others. And since I received the wrong kit from what I ordered (ordered the "complete" kit which is supposed to come with 7psi, but got sent a "tuner" kit by the vendor - long story, don't ask :( ), I have no way of knowing. Is there any chart that reports SC pulley size vs crank pulley size vs psi (on our stock cars)? Basically I want to know at what boost I should really be at (pulley-wise) to see if I am where I should be in power or if I should start checking for leaks. |
10-13-2012, 09:41 AM | #2 |
Drives: 2006 Z06 Join Date: Oct 2010
Boost depends on other things too, cam, intake, exhaust, elevation, etc. The sensor is accurate, but there is no such thing as a "5psi" pulley or "7psi" pulley. The pulley I have some see 22psi but I see 10. Elevation, heads, cam, crank pulley size, etc all play a huge role.
Nick
Corvette Z06 -1200ish rwhp |
10-13-2012, 10:25 AM | #3 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
I have a ZR1 sensor in my Maggie car and the boost levels on the ECM pretty much match the boost readings on my boost gauge.
10-13-2012, 07:42 PM | #4 |
Drives: IOM 2SS/RS M6 Join Date: Oct 2009
A 4.63 pulley will make 6psi with a P1 and no other mods..
2010 2SS..LS3..Procharger..4l80e..DSS 9"
10-13-2012, 10:05 PM | #5 |
Drives: Several... Join Date: May 2009
As long as you have the correct MAP scaler and MAP offset values the sensor is dead on...nobody knows that sensor better then Bosch and GM gets the data from them. It should be;
MAP Scaler 312.5000 MAP offset -11.25 Howard |
10-13-2012, 11:28 PM | #6 |
Drives: 2010 2ss/RS 4l80. 2009 2500 HD Join Date: Mar 2009
Is that all that needs to be changed in order to run zr1 map? Won't throw any thing else off in the tune?
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379 FNSS Racing! |
10-15-2012, 12:16 PM | #7 |
3000 hp 648 ci beast
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3 Join Date: Jul 2009
Running boost over a few psi with the stock MAP sensor will cause you AFR to go lean do to the fact that the Inj rail press delta is reported wrong. Putting the ZR1 map sensor in with the correct scaler and offsets will make everything work as its supposed to. If your custome tune corrected for this error by fudging the MAF table or PE table then you could be a little rich when you change out the sensor. Your tuner should be able to correct this when he changes your map settings. My stock Whipple tune did nothing to compensate for this error and went about 5% lean before I changed to the ZR1 map sensor.
2SS/RS, LS3, 6M, IOM w/black hockey, IO interior, sunroof
mods: ******** setup. Whipple supercharger....Need suspension upgrades now... 4" stroker kit, ARH, cam on my wish list. |
10-15-2012, 08:12 PM | #8 | ||
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
MAP Sensor Linear 312.50 kPa MAP Sensor Offset -11.25 kPa Kind regards, Jordan Priestley 888.308.6007 |
10-16-2012, 08:26 AM | #9 | |
Thanks
10-16-2012, 09:52 AM | #10 |
Just log your map sensor, probably reading in KPA. Then convert it.
Nick
10-16-2012, 02:06 PM | #11 |
First of all, thank you all for the information provided
--- I have no way to log it :( I did not tune it, it was a professional custom dyno tune. The tuner was as surprised as me of such low boost reading, but if the sensor is accurate (he did tune the ZR1 MAP sensor in with the offset and all) the most it read was 5.31 of boost. And yes, this is at sea level, although the humidity here sucks. Now, don't get me wrong, I'm happy at the results! That is almost 500rwhp with only 5 of boost I just wanted to see if there was more left on the table (ie. if the pulley size that was sent on the tuner kit is supposed to provide more "boost" on a completely stock car, then I would start checking for belt slipping or leaks, but if it's right at the mark where it should be, then I would go celebrating ) I took some quick measurements of diameters an the supercharger pulley was in between 4 3/4 inches & 5 inches (I would say it was 4.87" or very close to it), and the measurements at the crank pulley were in between 7 3/4 inches & 8inches (I would say it was ~7.87" give or take) I'm just a curious person Wanted to see if there was a chart for our cars stock (as I understand modifications such as headers, cams, lifts and other variables can lower the boost readings, even if the power stays the same or increases) somewhere along the lines that said: -If Crank Pulley 7 inches & Supercharger Pully 5 inches, you should see about 5 boost on a stock car -If Crank Pulley 7 inches & Supercharger Pully 4 inches, you should see about 7 boost on a stock car -If Crank Pulley 8 inches & Supercharger Pully 5 inches, you should see about 7 boost on a stock car p.s. these last numbers were randomly made up, just to illustrate what I was trying to find. |
10-18-2012, 11:10 PM | #12 |
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette Join Date: Sep 2010
Appreciate the info Redline Motorsports.
Other than needing the tune adjusted, is the ZR1 Map sensor plug and play with the current plug that is on the SS Camaros? Or do I need to buy a different cable to plug into the ZR1 MAP Sensor? |
10-19-2012, 07:38 AM | #13 | |
10-25-2012, 06:09 AM | #14 | |
Crank pulley (meassures 7.87 in diameter from outter lip to lip, i see no numbers imprinted on it but it was dark) Belt is a DB660I-008 Sea Level Would this help? |
