09-27-2012, 12:43 PM | #1 |
Drives: 2011 Camaro RS 2LT Join Date: Jul 2012
Solution: Is this causing the headers to whine?
09-27-2012, 12:59 PM | #2 |
Should I take it off?
09-27-2012, 01:02 PM | #3 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
Are you talking about the heat shield in the background? If so, you could remove it temporarily to make sure that it's the cause. Put it back on and dampen it somehow to keep it from making noise. DO NOT leave it off. There are brake lines and other bits behind it.
Bye bye, Bumblebee!
09-27-2012, 01:07 PM | #4 |
Drives: 2010 V6 M6 Camaro Join Date: Jun 2010
If that heat shield piece you think is causing the noise is a pretty quick job to unbolt and remove then I would probably try that. Take it off and do a quick test drive in the RPM/MPH where the noise is happening. If it still happens then you know its something else, if not then you found the problem. But I don't have experience with headers or working on that area of our cars, so if that piece is a complete b**** to remove then idk. Hopefully someone else will chime in.
09-27-2012, 01:09 PM | #5 | |
09-27-2012, 01:13 PM | #6 |
I think that is normal, I have the hood up right now doing an oil change so I just glanced over at it. On the driver's side the heat shield doesn't come as far forward as on the passenger side, you can just barely see it towards the trans tunnel.
09-27-2012, 01:17 PM | #7 |
I think the dealer removed my drivers side shield when I got them to install my headers. That was pricey....
09-27-2012, 01:30 PM | #8 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Since I'm 3,000 miles away and basing my opinion on a video, I'd have to say I don't know- give it a try.
But the image I had when I watched the vid was the heat shield (same material) that runs underneath the car. As you can see from the piece in the picture, it bends easily and could have inadvertently gotten moved or loosened. I would simply push that piece back away from the headers, it's there to protect the stuff behind it. If it seems loose, find the attachment points and tighten, but I think you'll find it's secure. Then get a jack and jackstands, and look under the car- inspecting the same material down the length of the vehicle, looking for loose/bent spots or anything else in close proximity to the length of the exhaust system. The vibration may not be coming from the headers or the immediate area, but more likely a part of the exhaust that was disturbed by the install of the headers. Good luck! I'm sure you'll track it down . Let us know when you find it. |
09-27-2012, 02:02 PM | #9 | |
crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
09-29-2012, 07:49 PM | #10 |
Tightened the bolts on my headers car is still making noise, Car still whines horribly.
Ugh.. Maybe its the clamped X-pipe? |
09-29-2012, 09:35 PM | #11 |
Drives: Camaro V6 1LT Manual Join Date: Jul 2011
09-30-2012, 09:49 AM | #12 |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
funny I have a whine at idle since my lt install as well. car runs great no whine while driving just at idle. When I pinch the return line of the catch can to the back of the engine the whine goes away. thiught it was the catch can but when i unhooked the can the whine was still there, It seems to be coming from my drivers side near the belts making me wonder if its a loose belt or too tight of a belt.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
09-30-2012, 04:49 PM | #13 |
10-01-2012, 09:47 PM | #14 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
