Formerly Lil'BlueCoupe
Drives: '13 2LT/RS Vert, Summit White Join Date: Jul 2009
I accidently had my transmission fliud drained while changing oil! how can ZI get it back in???? Please help!!!!!
Rollin' The Lunchbox
Drives: 2012 Camaro Ashen Grey Join Date: Aug 2012
Get a funnel and pour it back in the fill line...make sure it doesn't have metal flakes in it!!!! Best bet is use this experience wisely and get new fluid...
Sent from the front seat of the Amberlamps! |
10' 2SS MPD1 Hood MPD1 spoiler SS front splitter SW lt Headers VMaxx porteds TB JRE 93 octane tune |
Don't ask to pop my hood!
Drives: it's loud....... Join Date: Jun 2011
Who is doing it walmart? and how do you accidently drain tranny fluid? once you see red put drain plug back in fast, thats if your doing it yourself?
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS | 2010. ![]() |
I cannot locate the fill tube, these cars dont have a dipstick
![]() ![]() ![]() ![]() ![]() ![]() Drives: Sold: 2011 2SS/RS Join Date: Dec 2010
1. Don't drive it. Don't even start it.
2. I don't know if the A6 has a dipstick, but you need to find out how much fluid you drained. Each transmission has a fill procedure...some of the ones I worked on could be filled right through the dipstick. If that's the case, buy some proper fluid (there are different kinds...watch out...) and fill 'er up. 3. If all else fails, just have the car towed to the dealer or to the nearest shop that can fill a transmission. DON'T start the car, and DON'T drive the car unless the fluid is within the normal, specified level. |
#7 | |
#8 |
#9 | |
#10 |
The engine ran fine, I dropped all the oil and refilled it with the proper amount and ran the engine again and it ran fine, I think I only dropped about three to four quarts out of the tranny
#11 |
HUH? you changed the oil but its reading high after a change? are you sure you got all the old oil out? and put in 6qts, also reset your DIC oil% to 100%
#12 |
by Odeon
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM Join Date: Nov 2011
I agree, I think you should just have it towed. There is a way, at least for the 6L80, to refill it by snaking a tube from the engine bay down to the fill plug. This process is easier said than done.
"It works 60% of the time, every time."
![]() "Some say it's a waste of time, others say it's an incredible waste of time." "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy." 2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's) |
#13 | |
You didn't really read the thread, did you... OP: You are not the first person to do this...
Black 2SS ordered 1/4/2010, received 2/19/2010
#14 | |
![]() Drives: 2011 Camaro 2LT RS Join Date: Mar 2011
2011 LLT RS Black on Black Loaded. [x]Showstopper 45th Anniversary inspired Camaro RS Stripes, [x] MPD1 Spoiler, [x] GM Heritage Grille. [x] Removed RS and Bowtie Emblems. [x] 30% Tinted Headlight Armour DRL's. [X ] Ruff Racing R954 Wheels [X] Solo Cat Back Mach X-LLT Exhaust [X ] Vmax Ported throttle body [x] Halo SC Reverse Hood Kit [x] Showstopper Painted, Modded Engine Cover [x] Cold Air Inductions CAI [x] Tinted Tails and Black Bezels [x] Megan Racing Street Series Coilovers [x] Belltech F&R Sways
Check out my build thread! http://camaro5.com/forums/showthread.php?t=212178 |
