08-30-2012, 08:02 AM | #1 |
Drives: 2012 1SS LS3 M6 black on black :) Join Date: May 2012
Having problems with shifting.
I've had my 12' SS for over a month and it doesn't seem to shift from gear to gear very smoothly. It does shift nice sometimes but alot of the times it always feels like it is hanging up (if you want to call it that). More than not is shifts crappy. It feels like it's done this ever since i picked it up brand new 7/20. It's pretty frustrating on a new vehicle. :(
I put the hurst shifter in thinking it might be better but really it's not. I'm thinking maybe my next step will be synthetic transmission oil? Has anyone else experienced this? |
08-30-2012, 08:05 AM | #2 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Have you tried changing the clutch fluid?
08-30-2012, 08:21 AM | #3 |
No but i think i will when i change out the tranny fluid. I'll probably change out the rear diff. fluid too. From what i hear guys that are changing out the rear diff. fluid are finding lots of metal shavings/flakes in the fluid.
08-30-2012, 08:24 AM | #4 |
I changed mine at 1500 miles and it was filthy. Shifting greatly improved after replacing it with Royal Purple
08-30-2012, 08:27 AM | #5 |
Nice. I will be changing out the trans. fluid this weekend. Is changing out the clutch fluid easy? Do you have to bleed any air out of the system? I'm asking because i never changed out clutch fluid before but if it's a fairly easy job i'll try it.
08-30-2012, 10:57 AM | #6 |
Our clutch fluid reservoir is combined with our brake fluid reservoir. So it's the same concept as bleeding your brakes.
09-01-2012, 06:16 PM | #7 |
Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
I've found that our cars need about 20 minutes of driving or so for the trans to be fully warmed up. After that mine's like butter. I have the OEM Hurst but I don't think the shifter's the issue.
So if you have a short jaunt to work it may never really get warmed up to ideal operating temp.
1968 Camaro Convertible LS1, T56
09-01-2012, 09:21 PM | #8 | |
09-01-2012, 10:54 PM | #9 |
Drives: 2015 ZL1 Join Date: Aug 2011
Change your clutch fluid. Your dealer should do it for you under warranty.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
09-02-2012, 05:40 PM | #10 | |
This is a cheap mod and may want to consider it. Being this brand new you should take it into the dealer so your concern is documented.
