08-07-2012, 12:24 PM | #1 |
Drives: 2012 1SS LS3 M6 black on black :) Join Date: May 2012
Question on long tube headers.
Looking to do my first exhaust mod on my SS. Wanting to do long tube headers possibly kooks. Question is putting long tube headers on will they fit without any other modifications or pipes?
Thanks for any answers. |
08-07-2012, 12:26 PM | #2 |
Drives: 89 IROC 350 Join Date: Mar 2009
Bolt right up. It's an easy job. Just make sure you get the ones that mount to factory connection point (2.5") after the cats.
You will need either hi flow cats or off road pipes. It's a great upgrade but MAKE SURE YOU GET THE CAR TUNED after. People will tell you that you don't have to. They are only fooling themselves. And yes, it voids the warranty. |
08-07-2012, 12:28 PM | #3 |
Logic is dead
Just hope you're not one of the few who experience rubbing issues with the steering column. I have been working on this for awhile now, but my Kooks rub the steering column during right hand turns.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ - Vortech V3 Supercharger - Kooks Stepped Headers, Magnaflow 16580 - Suspension by Pfadt, Hotchkis. 2007 Trailblazer SS- Sold 2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold 1994 Camaro Z28 - Sold |
08-07-2012, 12:37 PM | #4 | |
Didn't know that. Thanks for the heads up. |
08-07-2012, 12:39 PM | #5 |
X SS
Drives: 2010 Camaro 2SSRSM6 1988 Sportside Join Date: Jan 2011
Installed Kooks a couple weeks ago = Incredible
MODS: PEDDERS XA COIL OVERS, STAGE 3 CAM, McLEOD CLUTCH, SKIP SHIFT, , HURST SHORT THROW, CAI INTAKE, SCOOP, WASHER RELO KIT, KOOKS HEADERS, KOOKS HI FLOW CATS, CUSTOM TUNE, QTP CUT OUTS, PAINTED STRIPES, PAINTED SS EMBLEMS, PAINTED FIN, PAINTED REAR TAIL LAMP BEZELS, HERITAGE GRILLE, DUCTS, AAC STUFF, BAER ROTORS, HAWK PADS, FUZZY DICE, LASER BEAMS, DISCO BALL, SYBIAN & 3 CHROME VALVE STEM CAPS................
08-07-2012, 12:42 PM | #6 |
Drives: 2012 AGM 2SS/RS Join Date: Mar 2012
Hey wheelman what happens when this occurs. I have had a slight problem with turns. My car feels like it bogs down until I straighten the wheel. I thought it was the fact that I went to heavier 22's....
08-07-2012, 12:47 PM | #7 | |
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
You can change out anything behind the cats without having to worry about warranty. So get any catback or axleback that you want. Your other option could be Shorty headers from JBA or ARH. The will bolt up to the factory down pipe. They don't perform near as well as long tubes but they do allow the engine to breath better and will increase your exhaust volume. |
08-07-2012, 12:50 PM | #8 |
Drives: 2010 Camaro SS/RS RJT A6 Join Date: Jul 2011
Headers will get you a few extra horses, but will void your warranty with a tune.They do just bolt on to your existing exhaust.Changing your mufflers or deleting them just pretty much changes your exhaust tone.I have TSP longtubes with no issues.
08-07-2012, 12:59 PM | #9 |
Owning SSes for 50 Years
I have Kooks on my SS and they are awesomely easy to install. I did that job by myself in about 4 hours in my garage on jack stands. I had these same headers on my 2010 and when I traded for an LS3, I took them off the old car and put them on the new one. So, that's twice installed. I had no clearance issues with the steering linkage, but even if you did, it's not that hard to disconnect.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
08-07-2012, 12:59 PM | #10 | |
Logic is dead
It's not the same feeling as headers rubbing the steering column, though. I feel a slight vibration in my steering wheel, and can actually hear a slight grind from the contact.
08-07-2012, 01:01 PM | #11 |
Drives: 2012 Camaro ZL1 SIM CTF Car M6 Join Date: Jan 2010
2012 ZL1,CTF Car, SIM MN6, Polished Wheels,The Rare Flat Black Insert. Proud member of the unofficial Camaro5 "Rodgers Chevrolet Fan Club" |
08-07-2012, 01:06 PM | #12 |
I've seen a select few with rubbing issues. The headers were returned and the new ones were fine. They are VERY close so any variance in construction could rub. My SW 1-7/8" had almost an inch between.
Like was said, anything behind the factory clamp after the cats and you're good to go. Lots of options out there. Be minded, a catback or axle back is only good for sound. No increase in power until you do CAI, headers, cats and tune. But if you're looking for a little aggressiveness, exhaust will do the trick! Lots to choose from. Good luck |
08-07-2012, 01:28 PM | #13 |
Yeah thats what I figured. It doesn't bother as much anymore. I got used to it like the sound of my headers bouncing off my garage walls and cars as I pass them.
08-07-2012, 08:41 PM | #14 | |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
