TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 03-11-2012, 05:20 PM   #1
masterofpuppets
Pulling your strings
masterofpuppets's Avatar
Drives: My girlfriend crazy with car talk
Plugs covered in oil. HELP!!!!
Decided to try pulling my plugs to see how they were and....we'll....pictures speak for themselves. First pic is drivers side, 2nd is pass. Dealership, here I come..... with mods.....and 52,000 miles......balls......
masterofpuppets is offline   Reply With Quote
Old 03-11-2012, 05:45 PM   #2
masterofpuppets
Looks like this should be covered under the 100,000k lp warranty. Catch can, flows axel back, and injen. Those shouldn't be related.....right?
Old 03-11-2012, 06:02 PM   #3
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
WOW! perhaps this is where all the oil is going that is mysteriously disappearing!
scrming is offline   Reply With Quote
Old 03-11-2012, 06:05 PM   #4
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Holy cow. That's bizarre. Maybe you're right, Screamin.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 03-11-2012, 06:08 PM   #5
chvyman
chvyman's Avatar
Drives: 2SS 45TH,gfx,blade spoiler,h grille
the oil appears to be on the outside of the plugs, maybe leaky valve covers. shouldn't be a biggie.
chvyman is offline   Reply With Quote
Old 03-11-2012, 06:12 PM   #6
masterofpuppets
Could explain the vacuum leak I've been chasing......
Old 03-11-2012, 08:55 PM   #7
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Awesome catch there!
Can't_C_Me is offline   Reply With Quote
Old 03-11-2012, 11:04 PM   #8
bmorecam
Drives: jealous vendors mad!! HAHA!!
im scared to find out how mine are going to look tomorrow.
Op, did you experience any problems or bad idle that made you want to check your plugs?
bmorecam is offline   Reply With Quote
Old 03-11-2012, 11:09 PM   #9
masterofpuppets
Yes. Been hunting the cause of hesitation under light throttle and rough idle for a while. I suspected vacuum leak but couldn't find it. Looks like I finally did. Plugs are healthy - or as good as a 52-53k old plug can. They look a little lean on the pass (oily) side, but drivers are perfect. Really looks to be a valve cover gasket or something like that, not the top end motor rebuild I thought when I first pulled it.
No cel, no sign other than rough idle and throttle hesitation. If you're having this problem, pull your plugs. But pull atleast one from both sides - I pulled a drivers side plug a few months ago because they're less of a 'pain' to get to. Pull both.
Old 03-11-2012, 11:38 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Are you routing your Rx catch can line over that area?
Looks like the oil is falling in on top and pooling around that left side plug.
Perhaps you've got your vacuum leak somewhere in that line (hard plastic is cracked?) and its tracking down something and ending up in the sparkplugs hole(s).
Ventmaster is offline   Reply With Quote
Old 03-11-2012, 11:56 PM   #11
masterofpuppets
No. No oil outside the motor and my line from the crank to the rx runs in that area, but not that close. It's internal. Spark plug seal/valve cover gasket is my guess. Makes sense. Plugs are in between the cams in the valve cover. Bad seal = hello oil and hello vacuum leak issue ive been having
Old 03-12-2012, 12:39 PM   #12
masterofpuppets
Pretty sure I just got an epic 4 hour run-around.
Took it to my dealer. They said they couldn't find anything. However, despite me telling them I suspect a vacuum leak and showing them the picture above, they didn't check anything to do with the valve cover or the plug wells. They hooked it up to the computer, no codes..... told them that. Reset ECU.... did that saturday. They said "oil in the spark wells isnot uncommon for an engine with that many miles"....huh?? 53,000 miles? They didn't even pull that plug! My engine bay is fairly dirty thanks to not running the engine cover and a lot of construction on my drive, and I see no sign they touched that side of the motor.
Saturday I'm going to pull all 3 from that bank and figure out if they all have oil. If it's just one, bad spark seal. That shoudn't be too hard to fix.
Old 03-12-2012, 12:43 PM   #13
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
well, at least you have it documented in case it becomes an issue in the future.
christianmotox is offline   Reply With Quote
Old 03-12-2012, 03:23 PM   #14
masterofpuppets
Damn right. Saving the service order and the computer results they gave me.
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! JDP Motorsports V8 Bolt-Ons & Tunes 137 08-13-2014 03:06 PM
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 06:11 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 01:51 AM
ON STAR OIL Life % T_MECO Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 04-25-2010 08:55 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
