Roto-Fab
Old 03-08-2012, 12:45 AM   #1
Phase V
Summer
Phase V's Avatar
Drives: 2010 2SS/RS IOM w/ Black Stripes
Send a message via AIM to Phase V Send a message via Yahoo to Phase V Send a message via Skype™ to Phase V
KooKs Headers
Anyone know if the kooks 1 7/8 headers will fit onto the stock exhaust?
CAI intake, Rotofab W/W Reservoir, Hurst Shifter, Skip-Shift Eliminator
AAC lighting, Kooks LT headers w/ high flow cats and Borla ATAK cat-back
Restoring or need parts for a Chevy. Look no further than Don's East Coast Restorations
Phase V is offline   Reply With Quote
Old 03-08-2012, 01:49 AM   #2
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Yea stock is 2.5 in. When you order just tell them what you are doing the HF cats will have a 2.5 outlet or the off road pipe will have a 2.5 outlet.
Slickcas is offline   Reply With Quote
Old 03-08-2012, 05:21 AM   #3
Soundplus
Drives: 2012 Silver Ice SS2 RS
Yes you will be A OK )) love mine
Soundplus is offline   Reply With Quote
Old 03-08-2012, 08:05 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Actually....you don't even have to tell them anything other than it's for a 5th Gen Camaro. The will come with either a off-road connection pipe or you can upgrade to the HF cats. Either one of those will have a 3" inlet and a 2.5" outlet and will hook directly into your stock exhaust.
BTW: I highly recommend getting them ceramic coated. Mostly for looks than anything else. Here are some pics of where they will look like after a few thousand miles vs what they look like coated. Coating might slightly dull a little bit but basically will remain that same brightness. It's worth the extra money....especially if you get them from someone like Maryland Speed because the upgrade to coating is usally less than $200 and is done buy Jet Coat who has been in the business for a long time.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal
caverman is offline   Reply With Quote
Old 03-08-2012, 08:14 AM   #5
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I second that notion.
newagemuscle is offline   Reply With Quote
Old 03-08-2012, 09:26 AM   #6
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
+3 on the Jet Hot ceramic coating - worth every penny!!!
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 03-08-2012, 09:54 AM   #7
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
The price quote I got was about double the price you state for the polished 1300 coating from Jet Hot in North Carolina. Did you send your's to Jet Hot or have someone locally coat them? Also, you show Kooks in your sig, but you have pics of ARH. Is that pic just for an example?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 03-08-2012, 09:57 AM   #8
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Call Branden at Maryland Speed. He tossed in the coating for free when I bought mine. And it was Jet Coat. Very nice looking.
bannonm is offline   Reply With Quote
Old 03-08-2012, 10:06 AM   #9
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Were your's coated on the inside? Jet Hot coats their's inside and out. If coating is done by someone local, it is usually just the outside and is under $200. As you probably know, Jet Hot is the name of the facility that ceramic coats items. It is a ceramic coating. So it may be a ceramic coating, but it may not be Jet Hot. I'm just trying to figure out the quote, $340 + shipping to Jet Hot. I'm thinking Jet Coat is just the outside of the header and is different the Jet Hot. Most local shops can't do the polished, since it needs to be tumbled, from my understanding.
Old 03-08-2012, 10:13 AM   #10
bannonm
bannonm's Avatar
Hmm. Not sure about the inside. I wrote down what Branden told me when I was talking to him about the stepped headers. My notes say "Jet Hot - coating". I got a sticker from them as well because they shipped them to me directly after being coated . Best to call him and ask. His prices are very competitive and he's one of Kooks largest sellers.
Old 03-08-2012, 10:24 AM   #11
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Since it is Jet Hot, it should be coated on the inside, additional heat benefits as well as flow. Is it the polished finish or a silver/flat finish? I have a set of ARH I want coated, but at close to $400, how can I justify it?
Old 03-08-2012, 10:25 AM   #12
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I ordered my ceramic coated Kooks from Maryland Speed and they came from Jet-Hot and had the Jet-Hot paperwork. Call MS to get the best pricing. If I'm not mistaken they have a special going on right now.
http://www.camaro5.com/forums/showthread.php?t=206691
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-08-2012, 10:32 AM   #13
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Originally Posted by IndeedSS1 View Post
I ordered my ceramic coated Kooks from Maryland Speed and they came from Jet-Hot and had the Jet-Hot paperwork. Call MS to get teh best pricing. If I'm not mistaken they have a special going on right now.
I'm thinking that's what I should have done.:( I saw they were offering Kooks stepped headers for the same price as there regular awhile ago. But it's too late, already have mine. Was it a significant amount for having them coated?
Old 03-08-2012, 11:07 AM   #14
bannonm
bannonm's Avatar
Mine took 7 days at the coater and then 2 days shipped from NC to IL.
Shiny... A shame to have to hid them under the hood.
Kooks stepped headers vs ARH ...?? Nito Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 01-08-2014 04:57 PM
Borla Headers (off-road) vs Kooks headers (w or w/o HF Cats ) Bu3ali Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 03-02-2011 01:52 PM
Kooks Headers Installation Specials! Rich D Local Marketplace 4 02-27-2011 08:12 AM
