TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 09-25-2011, 04:38 AM   #1
HashimAzzouz
Drives: 2011 2SS/RS IOM ~ 2009 Traverse LT
Which is the best iPod?
Hi guys... my iPod touch sucks.. keep disconnecting every now & then.. hate it! I want to buy another one.. which one should i go for.. Classic, Shuffle or Nano.. I need the one that would work perfectly & charge in the same time!
Thanks guys.. appreciate it..
HashimAzzouz is offline   Reply With Quote
Old 09-25-2011, 05:19 AM   #2
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Disconnecting from what?
slick rick is offline   Reply With Quote
Old 09-25-2011, 05:34 AM   #3
HashimAzzouz
Disconnecting from the Head Unit.. plugged but the Head Unit can't read the damn iPod touch.. I wounder if the nano charges though!
Old 09-25-2011, 05:51 AM   #4
Dreamin
Drives: 2010 Camaro 2SS
I have bothan I=touch and nano ad they work the same. If you turn the car off with the i-pod it, the i-pod does not turn off so the battery drains. Either turn the stero off off switch to radio before turning the car off and the i-pod will turn off and not drain.
Dreamin is offline   Reply With Quote
Old 09-25-2011, 05:59 AM   #5
REDXIIIDave
El Chupacabra
REDXIIIDave's Avatar
Drives: 2011 2SS/RS A6 Black/Black
Speak English much? That is directed to the responder. Just get a flash drive. That is directed to the OP.
El Chupacabra
REDXIIIDave is offline   Reply With Quote
Old 09-25-2011, 08:30 AM   #6
emin7
1st State C5
emin7's Avatar
Drives: 2010 Camaro SIM 2LT/RS
My iPod touch seems to work fine
emin7 is offline   Reply With Quote
Old 09-25-2011, 08:37 AM   #7
TDevilsG
TDevilsG's Avatar
Drives: 2013 2LT Victory Red LFX
Assuming that it works with the Camaro (I have yet to test it out as my car is being built), I would definitely go with the Classic if you are a die-hard music lover. I bought a 160GB classic off of Ebay for a cheap price and its essentially a walking hard drive; you can fit FLAC music on it (typical songs range into the 40-50megs per song size) which stands for Free Lossless Audio Codec, which is essentially the highest quality form of a song you can find. I invested in an expensive pair of headphones for it (Turbine Monster Gold) but the quality with the two investments together is unbelievable.
TDevilsG is offline   Reply With Quote
Old 09-25-2011, 10:01 AM   #8
SWAT
Drives: 2011 2SS RS L99
Me too, 4th gen, 32g. No issues whatsoever?
SWAT is offline   Reply With Quote
Old 09-25-2011, 10:07 AM   #9
BlueDragonVT
BlueDragonVT's Avatar
Drives: 2011 IBM Camaro 2SS/RS
I would seriously encourage you to look beyond apple. There are better media players out there, for considerably less money. For your car, an earlier response was correct, get a flash drive. Cheapest option, you don't need an interface, since the car does that for you, and you can just leave it in the car.
BlueDragonVT is offline   Reply With Quote
Old 09-25-2011, 10:10 AM   #10
oldfriend
Drives: Fiat 500 E
I do have a I TOUCH and it works the way it was design , like some one said , you have to turn it off , or the I touch battery will go dead , and i am not a geek ,not even close !
oldfriend is offline   Reply With Quote
Old 09-25-2011, 10:24 AM   #11
Hendu
Hendu's Avatar
Drives: 2SS 45th Anniv LS3
If all of your music is purchased through itunes, I can see why you'd want to stick with apple.
I use my Nano in the car and have not had a problem with it. It's small and fits best in the console. My nano turns off (gen 5) by itself after no activity for some time.
Hendu is offline   Reply With Quote
Old 09-25-2011, 10:26 AM   #12
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Overflow is offline   Reply With Quote
Old 09-25-2011, 10:43 AM   #13
ZL1DREAMER
Graveyard Zombie
Drives: '12 2SS/45th
Another vote for the classic. Simply because it's the largest capacity currently available on the market by a pretty wide margin. If you're compressing your music to MP3 or 4 and only using a couple of megs of space per song, it'll be all you ever need for life.
Valor is not in having never fallen, but in rising back up each time you do.
ZL1DREAMER is offline   Reply With Quote
Old 09-25-2011, 10:58 AM   #14
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I have the Ipod touch and it works awesome. Not one problem ever.
BackinBlackSS/RS is offline   Reply With Quote
Had a great idea!....but didnt work :( CamaroC-17 5th Gen Camaro SS LS LT General Discussions 13 01-10-2011 08:27 AM
Multimedia Information ,USB, AUX, Bluetooth zahidismaeel Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 10-13-2010 01:06 AM
USB port The_Stache Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 85 09-20-2009 01:44 PM
