03-18-2011, 08:46 PM | #1 |
Drives: 2011 1lt rs camaro sim Join Date: Mar 2011
what gas do you use in your 1st rs
post said it all ^^
03-18-2011, 09:04 PM | #2 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
93 octane, but 87 works just as good.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
03-18-2011, 11:21 PM | #3 |
Use what GM tells you its in the manual, read it.
03-18-2011, 11:24 PM | #4 |
Drives: 2011 1SS Imperial Blue Metallic Join Date: Feb 2011
The manual recommends 93 octane.
03-18-2011, 11:26 PM | #5 |
Drives: 2LT RS Summit White Camaro Join Date: Jan 2011
I have a v6 RS, 93 still ok?
And is it ok to put 93 in if there's like a fourth of a tank of regular already in it? |
03-18-2011, 11:30 PM | #6 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
104 octane E85
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
03-18-2011, 11:32 PM | #7 |
Just a quick clarification the RS package adds nothing to powertrain of the car. I feel like I should say something about this before you get reemed for not being up to speed on your facts on a car forum. You have an LT which, means you have a 3.6L V6 just like the LS trim. You should be fine on 87 octane as modern car engines just retard the spark slightly to handle the lower fuel grade. Howsoever using lower octane fuel like 87 will yield less power from the engine than 93 octane. If you want the best performance go with 93. Also to answer your question yes you can mix fuel grades into one tank.
03-19-2011, 01:02 AM | #8 |
¡ʇuɐıןןıɹq
Drives: 2011 Camaro IOM 2SS/RS Join Date: Dec 2010
I've ran only 93 octane in mine.
03-19-2011, 01:18 AM | #9 |
I use garbage disposal and banana peels for fuel>>><<<
03-19-2011, 01:20 AM | #10 |
¡ʇuɐıןןıɹq
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
RS Logos | Bryan2230 | Cosmetics and Lighting Modification Discussions | 9 | 08-02-2010 03:09 PM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
If gas goes up, then get the V8 !! | Patriot | 5th Gen Camaro SS LS LT General Discussions | 37 | 04-28-2010 01:31 PM |
VIN # 6125 2SS RS Delivered June 1st !!! | ravensjeff | Camaro Price | Ordering | Tracking | Dealers Discussions | 15 | 06-01-2009 07:22 PM |
First 8 sec C6 Z06 on pump gas | CamaroSpike23 | General Automotive + Other Cars Discussion | 15 | 03-20-2009 07:43 PM |
