Old 10-14-2010, 11:53 PM   #1
Not His
Not His's Avatar
Drives: 2010 Chevy Camaro, IBM/LT1/RS
Peeling out
I'm not stupid, I know how to peel out, however, this car just won't do it.
Traction control is off, brake on, gas on, slowly let off brake, slight fishtale, let off brake and... nothing. No squeal, no nothing. Lame.
I don't try to do it very often, but you know, there are times that call for it. Tonight called for it and I ended up looking like a chick that doesn't know how to drive.
What am I doing wrong? I've never had a problem doing this before.
Not His is offline   Reply With Quote
Old 10-14-2010, 11:56 PM   #2
HarrisraTx
HarrisraTx's Avatar
Drives: 2LT/RS Black
I can peel out alot in mine. Try using the sport mode and pedal all the way down. Then let off brake and watch the magic. Wouldnt try it too much tho bad on brakes and tires
HarrisraTx is offline   Reply With Quote
Old 10-15-2010, 12:04 AM   #3
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
call me, then slap one of these babies on... you will have no problems after that (I know, it probably won't bolt up to a sixer)
Seriously though, I have seen many threads where people have this trouble. For example, this one or this one, or this one (2 pages)
Apex Paul is offline   Reply With Quote
Old 10-15-2010, 12:55 AM   #4
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
That supercharger looks sick Paul.... Dammmnnnn
CyberDan is offline   Reply With Quote
Old 10-15-2010, 01:04 AM   #5
Brownhornitt
Brownhornitt's Avatar
Drives: 2006 White Corvette Convertible
Are you in an automatic? I didn't know there was a trick to it. In my Formula 350 I just stomped the pedal and shit hit the fan.
The lack of torque in our cars probably means that you can't do that in an automatic. Right?
The Corvette is an animal.
Brownhornitt is offline   Reply With Quote
Old 10-15-2010, 05:56 AM   #6
Hemlawk
AwesomeBillDawesonville
Hemlawk's Avatar
Drives: CGM 2SS/RS =)
Not His, it's your large rims and summer tires. They stick like crazy it's a good thing but I hear ya.
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM
Hemlawk is offline   Reply With Quote
Old 10-15-2010, 07:46 AM   #7
SC2150
Drives: 2012 Camaro RS, RX supercharged
That would do it for sure!
But addressing the OP, why would you want to spin the tires? The goal for quick acceleration is to NOT spin. Get the power to the ground with little or no spinning is the goal we spend thousands on....
SC2150 is offline   Reply With Quote
Old 10-15-2010, 07:52 AM   #8
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Install some line locks. Depress the brake, turn em on release the brake and press the gas. Or you will need to do some wieght shift by rolling out a bit then tap the brake to shift the wieght forward off the rear end. Must admit I have never tried a v6 Camaro but have done it with far less powerful cars.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 10-15-2010, 08:05 AM   #9
gatorlover
gatorlover's Avatar
Drives: 2013 AGM 1SS/RS 1LE
Just beautiful!!!! If I only have the money.
Can you share any specs and info on integrating this to the l99?
2013 Ashen Grey Metallic 1SS/1LE, NPP, Camera
(1 of 43 produced)
gatorlover is offline   Reply With Quote
Old 10-15-2010, 08:27 AM   #10
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Another one you may want to consider is the Edelbrock E-Force ... It's looks and performance is basically the same as the OEM LS9 setup. And I've seen them listed as low as $5500.00 ...
SlingShot is offline   Reply With Quote
Old 10-15-2010, 08:35 AM   #11
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
The 19 wi thall season tires spin like crazy. No hookup at all. If you like that sort of thing switch out youR rs tires for the 19ers.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 10-15-2010, 08:36 AM   #12
Hemlawk
Hemlawk's Avatar
Peeling out, burn outs & power braking is the old school way of showing off that POWER!
Who the heck doesn't like a good 'ol roasting of the tires. Especially when the tires aren't yours. Haha
Old 10-15-2010, 08:55 AM   #13
Steve Dallas
Commits weekly crime
Steve Dallas's Avatar
Drives: 2017 Camaro 1LT
V6?
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime.
Steve Dallas is offline   Reply With Quote
Old 10-15-2010, 09:04 AM   #14
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by Steve Dallas View Post
V6?
hers is a 1lt so it is a six. But mine is a 2lt six and i have got my tires makeing noise with tracktion controll on. But i do have an M6 tranny not sure about the op
GM not honoring my Camaro paint warranty; paint cracking and peeling all over the car jackr67 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 132 08-03-2010 09:50 AM
paint peeling? Amn_Bly Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 07-29-2010 05:14 PM
Request for Copy of TSB 09-08-51-005? (Peeling Paint) Hicompression Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 15 07-14-2010 11:04 PM
Paint peeling at corners of bumpers FirstCamaro2k10 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 26 06-22-2010 04:26 PM
Peeling paint Mrhavasu Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 09-28-2009 05:54 PM
