Old 09-30-2017, 01:31 PM   #1
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
LT pad and rotor upgrade?? + questions ...
Guys my stock LT brakes havent let me down ever and I drive the piss out of my car but a little boost in performance wouldn't hurt. So I was thinking that when it comes time for me to install new brake pads I would like to put something a little better in. Front and rear.
Has anyone found upgrade pads or rotors for the LT brakes?
Also for anyone who upgraded to the 4 piston brembos from the SS ...are the calipers heavier or lighter than the LT calipers?
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 10-02-2017, 07:08 AM   #2
rorymick
rorymick's Avatar
EBC Yellowstuff high performance street front brake pads part # DP41210R
EBC slotted and drilled REAR brake discs part # GD1694
Powerstop drilled and slotted front rotors part #AR82187XPR
Old 10-02-2017, 11:12 AM   #3
Scoooter12
Scoooter12's Avatar
Drives: 2016 Camaro 1lt 2.0 White
Cool! looks like you found some pads and rotors?
Seems like everyone has been saying that drilled rotors actually reduce brake performance but some people still like them for aesthetics!
For rear pads you could get some pads from a v6 1le...
I'm waiting for my front brembos to come in. I will be weighing them to compare to the stock LT brakes. I'll post my findings for you if I remember!
Scoooter12 is offline   Reply With Quote
Old 10-02-2017, 01:09 PM   #4
rorymick
rorymick's Avatar
I was wondering if the V6 1LE uses the LT brakes in the rear but wasn't sure. I found drilled and slotted rotors for the front and the rear I just gotta post up the part numbers.
The 4 piston brembos are really the best way to go for the front. I don't plan on tracking my car so of the brembos weigh substantially more than the LT's then I'll stick with the LT's.
If you can weigh the stock stuff and the brembo stuff that would be great for the community . Rotors and calipers lol.
Old 10-02-2017, 08:10 PM   #5
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
I still think the Brembos would be a great upgrade even if you never track the car. I prefer the pedal feel and bite in my ATS and SS Sedan over my Camaro. It will eventually get a Brembo upgrade as well!
I think it's amazing that nowadays you can upgrade your brakes relatively cheaply with name brand performance parts provided from the OEM! 15 years ago when the 4th Gens were new, you'd be looking at spending $4-$5k for a name brand brake upgrade. Now you can do it for under a grand.
ChicagoTommy is offline   Reply With Quote
Old 10-04-2017, 12:27 PM   #6
Chez
Chez's Avatar
Originally Posted by cooper1965 View Post
1LE option includes J55 RPO on V6, that is a heavy duty system. Part number for the pads: 23344220 caliper: 13511034... So that is a no go on pad swapp..
Worked fine for me.
Traded-2017 1LT V6 GMPP Intake, Flowmaster American Thunder axle-back, Vmax Ported throttle body, ZL1/1LE sway bars, V6 1LE Suspension,SEMA grille, Blade spoiler, Apex PS-7 18x10
Chez is offline   Reply With Quote
Old 10-04-2017, 01:38 PM   #7
Chez
Chez's Avatar
[QUOTE=cooper1965;9928721]^ Do you have J6G rpo, the regular heavy duty brake option?
It looks to me like they are a different physical size between regular non hd pad VS v61le pad. Doesn't make much sense to use a different caliper.[/QUOTE
Non-HD brakes. Maybe the difference is internal? Possibly more pad material?
The pads look identical in shape.
Old 10-05-2017, 09:40 AM   #8
Scoooter12
Scoooter12's Avatar
I can only find two part numbers for the 1LT rear caliper. I checked 2016 and 2017 model year as well.
13511033 for the left hand
13511034 for the right hand
Theres only 2 brake pad part numbers for the rear as well... at least that I can find.unfortunately I don't know if there is a way to search by rpo code either.
This is how I saw it listed
23344214 ~LT without performance package
23344214 ~LT without performance package, without heavy duty
23344220 ~LT with performance
23344220 ~LT with performance, without heavy duty
Sooooo to me, it looks like there is a performance pad and a non-performance pad.
Plus it sounds like Chez has already swapped pads. and was fine
Old 10-05-2017, 09:51 AM   #9
Scoooter12
Scoooter12's Avatar
rorymick
You asked for weights on the LT vs SS front brake rotors and calipers.
I came home to a bunch of boxes last night... so here you go.
2017 Camaro SS Front 4 Piston:
Rotor: 25.8lbs each
Caliper: 13.8lbs each
2016 Camaro LT Front:
Rotor: 20.6lbs each
Caliper:15.8lbs each
72.8lbs for the LT brakes
79.2lbs for the SS Brembos
Old 01-01-2018, 09:18 AM   #10
outobie
Drives: 2017 2LT RS Convertible
Besides calipers and rotors, are there any other parts that need to be swapped to convert to the SS 4 pot brembos?
outobie is offline   Reply With Quote
Old 01-02-2018, 12:52 PM   #11
Scoooter12
Scoooter12's Avatar
Nope, rotors, calipers, pads, and the brake line should be attached to the calipers. shop around though ive seen some brand new 4piston kits from gm for $450 lately...
Old 01-02-2018, 12:55 PM   #12
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
R1 Concepts has some nice rotor and pad options for us.
Old 08-17-2018, 04:02 PM   #13
shadogt
shadogt's Avatar
Drives: 2016 Chevy Camaro RS V6 M6
Hey man, great info @rorymick! Thanks a ton for those part numbers.
Any experience with the EBC Yellowstuff pads? I can't find a definitive answer telling me that p/n DP41210R will fit a LT without the Brembo upgrade.
shadogt is offline   Reply With Quote
Old 08-17-2018, 04:08 PM   #14
shadogt
shadogt's Avatar
(Reply above, but adding the quote
