TireRack
Old 05-10-2019, 12:54 PM   #1
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
repairing curber spillter
I curbed the driver corner of my ACS T4 splitter. Nothing major, but enough to crack it to the resin weave. hat material would i use to fill it?
thanks
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 05-10-2019, 01:20 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Some sort of body filler is what you need. 3M makes all kinds. You'll find this at most auto parts type stores. Clean then sand then clean again the area around the damage and then apply filler as instructed. Once dry you can sand and shape to the splitter, and then clean, prime, paint. Plenty of You Tube videos out there on using the stuff (and how to paint) that are much more detailed than what I just said. Good luck!
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 05-10-2019, 01:49 PM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Depends, is it plastic or fiberglass?
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-10-2019, 02:10 PM   #4
gm2376
gm2376's Avatar
seems to be fiberglass or some sort of resin
https://acscomposite.com/products/ac...aro-ss-only-v8
Old 05-10-2019, 02:42 PM   #5
gm2376
gm2376's Avatar
http://
Old 05-10-2019, 03:05 PM   #6
BETO713
BETO713's Avatar
Drives: 2012 Camaro 2LT RS
Looks like some form of plastic to me, maybe just sand smooth to make it look alot better?
Edit: Nevermind i see the little fibers now. I have no idea how to go about repairing that by oneself
BETO713 is offline   Reply With Quote
Old 05-10-2019, 06:37 PM   #7
gringo
gringo's Avatar
Drives: Camaro V6
Since it'll probably happen again, I suggest using that door molding trim stuff to protect the bottom edge.
gringo is offline   Reply With Quote
Old 05-11-2019, 03:06 PM   #8
Grey2ss
Grey2ss's Avatar
Drives: 2015 Camaro 2ss
I had my splitter crack about 4 inches when I first got it. I used JB Weld Plastic Bonder and it worked awesome. You can then sand it and I just painted mine with rattle paint. To really cover it up I used Plasti Dip the first time but didn't really like the texture.
Grey2ss is offline   Reply With Quote
Old 05-12-2019, 06:57 PM   #9
DagoCountyGee
DagoCountyGee's Avatar
Drives: '15 SS
This is why i bought a cheap ebay splitter. Havent had issues with it yet
Follow My Car on INSTAGRAMhttp://www.instagram.com/forb1dd3n_ss
DagoCountyGee is offline   Reply With Quote
Old 05-12-2019, 08:14 PM   #10
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Something that small can be fixed with just a couple brush strokes of resin. Then use body filler to shape it. Prime and paint. It's not that bad at all.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
