Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Wheels / Tires
Old 05-17-2019, 10:45 AM   #1
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
► APEX | Flow Formed Lightweight Camaro Wheels - Built to Perform
Questions?
Call: 925-245-0773
Email: expert@apexwheels.com
Web: http://www.apexwheels.com?utm_source...content=thread
Hours: M-F 9a-5p PST
APEX Flow Formed Wheels
Over the last few years, APEX has been a great solution for Camaro enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 design addresses the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer SM-10 design (coming soon!) provides a step-up in strength and true race wheel features like I-beam spokes and reinforced inner lip.
➡︎ Perfect fit
➡︎ Made to work with big brake kits
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Order Now
Designs & Finishes
ARC-8 - 19"
ARC-8: The lightest wheel design we make. Also the most affordable. A deep lug recess allows for an open center for quick wheel changes. Offered in Profile 3, the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Available in 19” diameters.
SM-10 - 18"& 19"
SM-10: Modern design with reinforced lips and I-beam spokes. The SM-10 spokes were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke.
Fit Matters
The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each wheel combines many great features to meet the different brake caliper, strut, and fender clearance needs of modern Camaros.
100% OEM Compatibility
No need to change your wheel bolts, center caps, or TPMS sensors. All APEX Camaro wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug nuts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our Camaro wheels use a 67.1mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black APEX center caps, but you can also snap-in OEM 6th Gen caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
Brake Clearance
A lot of room in a tight space. Spoke clearance is only half the problem. The barrel construction on a wheel also needs to be big enough to clear the sides of your caliper and rotor. Many aftermarket wheels that have aesthetic compromises in their design may work with smaller stock brakes, or smaller diameter big brake kits, but the larger kits will pose a major problem. The barrel of the ARC-8 wheel offers unmatched caliper clearance because wheels shouldn’t limit your choice of aftermarket brake kits, and brake kits shouldn’t force you to run oversized wheels. We 2D modeled most Big Brake Kits available in Solidworks and tweaked the wheel design of the ARC-8 prior to production in order to fit as many kits as possible, including ZL1 and Z/28 setups.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX Camaro wheels with a 5x120mm bolt pattern are purpose built featuring a 67.1mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our Camaro wheels to be interchangeable with the OE 6th Gen cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
OEM Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
APEX Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
APEX Flow Formed Wheel Gallery
Order Now
Questions?
Call: 925-245-0773
Web: www.apexwheels.com
Cory - Fitment Specialist | Phone: 925.245.0773 | experts@apexraceparts.com
Website | Instagram | Facebook | Blog
Apex Wheels is offline   Reply With Quote
Old 06-07-2019, 07:13 AM   #2
kaamacat
Drives: 2018 ZL1/1LE Red
What is the latest ETA on ARC8's for the ZL1/1LE in 19x11 and 19x12?
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 06-11-2019, 08:51 AM   #3
Jdzumwalt
Drives: 2019 ZL1 1LE, the comeback
When the group buy happened i was told july-august.
Jdzumwalt is offline   Reply With Quote
Old 06-13-2019, 02:42 AM   #4
Apex Wheels
Drives: Camaro Z28
Hi, we are anticipating the 19x12" wheels to be shipping out to customers in late August/early September.
- Cory
Old 07-25-2019, 05:12 PM   #5
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Is it too late to get in on the group buy? I'm super interested, thanks!
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
angryBits is offline   Reply With Quote
Old 07-31-2019, 12:25 PM   #6
kaamacat
Just spoke with Cory @ Apex... Excellent conversation and I look forward to getting a set when they are available. (Not to far off)
BobR
2009 Porsche C2S
2001 Ferrari 360
Old 09-12-2019, 12:17 PM   #7
Akirasoft
Drives: 2018 ZL1 1LE, 2015 X3 x35i M-Sport
- Cory
Hey Cory! we're inching towards mid September now. Any word on if these might ship this calendar year?
TIA!
Akirasoft is offline   Reply With Quote
Old 09-23-2019, 07:31 PM   #8
Homeless Junkie
Homeless Junkie's Avatar
Drives: around in circles few days a month
TIA!
+1 I’m starting to regret ordering these wheels. I’ve been to track 4 days, 6 if Apexi pushes the date again, without spare the rims and tires I ordered months ago.
Avatar photo credit: Dito Milian at gotbluemilk.com
Homeless Junkie is offline   Reply With Quote
Old 09-23-2019, 08:36 PM   #9
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
They told me second week of October a couple of weeks ago for the 19x12s
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 09-24-2019, 11:51 AM   #10
kaamacat
My set is paid for and do hope they show in a week or two at the latest... Don't want to be last minute before my 10/20 VIR event.
BobR
2009 Porsche C2S
2001 Ferrari 360
Old 10-02-2019, 09:37 AM   #11
Homeless Junkie
Didn’t get the wheels in time for yet again another weekend but.. I did get an email saying my set of wheels will ship 10/10! Yay me
Old 10-02-2019, 01:52 PM   #12
Chris V
Chris V's Avatar
Just got my email with tracking information for 4 19x12s.
Old 04-30-2020, 06:28 PM   #13
Apex Wheels
Drives: Camaro Z28
Exciting Announcement for Camaro owners! By popular demand, the ARC-8 is now available in Satin Bronze. In stock now in 19x10" ET20 with more sizes coming mid-summer.
- Cory
Old 05-26-2020, 07:47 AM   #14
Hailwood
Drives: 2019 SS 1LE
Any updates on the matte bronze availability in other sizes? Mostly interested in the direct fit 19x11 et43. I'd pick up the fronts now if I knew the rears would be available within the next month or so.
Hailwood is offline   Reply With Quote
