Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 07-18-2014, 12:14 PM   #1
Mmuscat1369
Mmuscat1369's Avatar
Drives: 2013 Camaro 1SS/RS
PSI varies
i have a 2013 1SS/RS (not a daily driver) and i notice that the PSI varies from when the car sits and then once the tires get warmed up. My PSI while car is parked for a while in garage can all the way down to 30-32 PSI but as soon as i drive her it goes up to 35front and 36back is that normal - or should i not worry about it?
Mmuscat1369 is offline   Reply With Quote
Old 07-18-2014, 12:18 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes....normal. Pressure increases as tire temp increases. Perfectly normal. Tire pressures should be checked cold. You can use nitrogen if you want and the pressure variance will be less....but either way....not a big deal.
Old 07-18-2014, 12:20 PM   #3
Gillis
Drives: Car
Completely normal. When tires heat up the pressure goes up. This is why you must always go by the PSI when completely cold. PSI should be 36 cold. My sensors read 3 pounds low so I know I'm good if they are at 33 when cold.
Gillis is offline   Reply With Quote
Old 07-18-2014, 12:33 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
PV=RT
The only thing you should worry about is that 30 PSI cold is too soft.
Inflate your cold tires to 36 PSI, early in the day, before the sun shines on them.
Old 07-18-2014, 12:37 PM   #5
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
Originally Posted by Rock-It Man View Post
PV=RT
^ What he said...
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
Old 07-18-2014, 12:53 PM   #6
Swacer
Drives: 2018 GT350
PV=nRT
If volume stays the same, the moles and gas constant stay the same, and your temp goes up (friction creates heat...)...your PRESSURE goes up.
Wasn't this 9th grade physics?
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 07-18-2014, 12:54 PM   #7
Swacer
Drives: 2018 GT350
PV=RT
Damn...beat me to it lol
Old 07-18-2014, 12:56 PM   #8
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
PV=RT
Depends what tire you have......that is way to much for many.
gajagfan is offline   Reply With Quote
Old 07-19-2014, 06:48 PM   #9
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
Don't they teach any principles of science in any school anymore?
RJT Impala is offline   Reply With Quote
Old 07-19-2014, 09:19 PM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
36 for SS P zeros?
Old 07-20-2014, 12:44 AM   #11
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Originally Posted by JCunningham View Post
36 for SS P zeros?
That's correct.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 07-20-2014, 02:00 AM   #12
homewrecker
homewrecker's Avatar
Drives: '04 Z06, '14BMW M235i, '15 SS/1LE
I drive about 1500 miles a month and I inflate my tires cold to 38. The ride seems a little harsher but I only need to fill air every other month
homewrecker is offline   Reply With Quote
Old 07-20-2014, 04:09 AM   #13
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Check the driver's door sill (lower rear) area for your car's correct pressure
Old 07-20-2014, 09:10 AM   #14
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
Drives: '12SS/2SS/45TH-'06 2500HD/Silverado
PZeros are supposed to be 36 cold. I like mine about 1-2 lower than that in the warm weather because I found that at 36, they get too high and wear more in the center than evenly to the outside. Since lowering it, they are wearing more evenly when hot.
2012 Camaro SS 2SS 45TH Anniversary Edition
MYDLIFECRISIS is offline   Reply With Quote
