Old 09-16-2015, 06:53 PM   #407
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
Would you say the gt pp is much closer to the 1ss?
obzidian is offline   Reply With Quote
Old 09-16-2015, 07:02 PM   #408
VF-22
Drives: 4 Wheels
I would say the GT/PP is much closer to the SS.
Lets not use 1SS/2SS because the difference between them is just luxury/creature comforts. As overall/performance/mechanical they are the same.
the GT/PP adds ($2,495 package). When you factor this in, the GT is much closer in price to the SS Camaro. $4000 quickly becomes $1500 difference.
• 19" X 9"(F) 19" X 9.5" (R) Ebony Black Painted Aluminum
Wheel
• 255/40R19 (F) 275/40R19 (R) Summer Only Tires1
• Brembo™ Six-Piston Front Brake Calipers with Larger Rotors
• “Engine Turn” Aluminum Instrument Panel Appliques
• Gauge Pack (Oil Pressure and Vacuum)
• Heavy-duty Front Springs
• K-Brace
• Larger Radiator
• Spoiler Delete
• Strut-tower Brace
• TORSENŪ Differential with 3.73 Axle Ratio
• Unique Chassis Tuning
• Unique Stability Control, EPAS and ABS Tuning
• Upsized Rear Sway Bar
Lots of this is included in the SS already.
SS has on it already
• Wheels, 20" x 8.5" (50.8 cm x 21.6 cm) front and 20" x 9.5" (50.8 cm x 24.1 cm) rear bright 5-spoke Silver-painted aluminum
Tires, 245/40ZR20 front and 275/35ZR20 rear, blackwall, summer-only, run-flat
Brakes, Brembo 4-piston front and rear, performance, 4-wheel antilock, 4-wheel disc
Suspension, Performance
Rear axle, 3.73 ratio
Cooling, external engine oil cooler, Cooling system, extra capacity,Cooler, engine coolant, auxiliary
• Bracing. I can't speak to all the parts on the Camaro/Mustang. But obviously the SS has a ton of it built it and the Mustang has to add it via the PP.
VF-22 is offline   Reply With Quote
Old 09-16-2015, 07:13 PM   #409
GMGP5X
GMGP5X's Avatar
Drives: 2011 2LT RS VR 2008 Silverado 2500
Wheel
• K-Brace
• Larger Radiator
• Spoiler Delete
• Strut-tower Brace
Rear end cooler for the SS also. Correct?
2LT RS VR / ARK DTS Cat back exhaust / Roto-Fab CAI / RPI stealth mud guards /Defender works billet chrome door sills/ DIY painted engine cover, trunk corners, and brake rotors / RX catch can / Team LLT badges. Team LLT
GMGP5X is offline   Reply With Quote
Old 09-16-2015, 07:33 PM   #410
VF-22
Drives: 4 Wheels
Yah I didnt paste all of it...
Cooler, rear differential
Cooler, transmission oil
Just saying the GT needs to add the PP to get what the SS has standard.
http://www.gmfleetorderguide.com/NAS...page=6&butID=3
Old 09-16-2015, 07:56 PM   #411
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
I think it has to do with the Auto owning the GT/PP if it had it. Ford still caters to the manual fanboys in America so they only offered it in the manual. In Europe the GT Auto gets the PP. I also think they are holding it over for another new 'option'.
8 speed is far enough for an auto IMO. I think Ford was dumb for not offering an 8 speed in the '15 Mustang. They are far behind the times. Ford seems to updated every few years where they only put so much out.
Actually the SS gets more then just coolers. Talking GT without PP here vs SS.
SS has 3.73 RAR vs the GT that has 3.15s (auto) or 3.33s (Manual). Thats an upgrade for $400 for 3.55s or you have to get the PP for 3.73.
SS gets 20" wheels and staggered set up. GT has 18" wheels without upgrade
SS has run flat Summer tires. GT has all seasons.
Also the SS gets a performance /track suspension where the GT has a sports one (similar to LT on V6).
So the GT needs a lot more on it to make it similar to the 1SS/2SS.
Ah so it was just a US market issue, bad move. Definitely helped me mark the GT off my list.
Yea Ford was behind with auto trans development, hence the need to work together with GM. GM gets to split development cost and Ford gets help getting up to speed. Win win for both.
I don't really think the gearing is an upgrade. Gearing choices have more to do with FE/Performance and then ultimately choice of wheels and tires. Also note the A8 SS is geared lower than the Challenger/Charger.
The 5th gen had 20" wheels to, so again not really a performance upgrade as much as style. You can be sure the 20's weigh more than the 19's Ford is using on the PP.
The 6th gen 1SS will not be as firm as the outgoing 1LE. You wouldn't want the base suspension too firm otherwise you might turn away buyers. Most of the suspension for the SS was designed to save weight, so that's what you are paying for. Maybe some would be happier with a heavier car, but Team Camaro was not as that was chief among the complaints.
Again, the price difference has more to do with weight savings and more standard features than anything. Probably less than $1k for the additional cooling features.
Old 09-16-2015, 08:38 PM   #412
VF-22
Drives: 4 Wheels
Right but I'm talking how the Mustang is cheaper. 20" wheels on the Mustang are $1200. The SS has them. The gearing the SS has. The GT needs to spend $400 to get it. Etc. etc. SS comes with Brembos. That's more $$ on the GT or aftermarket, etc...Those things aren't free on the SS they are part of the $4k difference.
Old 09-16-2015, 08:45 PM   #413
SuperSound
SuperSound's Avatar
Ok I was sticking to things that made the '16 more expensive than the '15 in terms of performance.
I can tell you easier than that why the Mustang and Dodge RTs are cheaper, they are slower in every performance category
Old 09-16-2015, 10:18 PM   #414
khell86
Drives: 2012 Ford Focus
I dont know if they'll introduce just DI alone, but the new raptor shows a lot of upcoming technology Ford will be using. The new raptor sports the new 10 speed and dual injection. I have a feeling this will end up in the mustang.
khell86 is offline   Reply With Quote
Old 09-16-2015, 10:38 PM   #415
joemosfet
joemosfet's Avatar
Drives: 2014 Camaro SS
I had a bicycle that had one of those.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior
Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net
joemosfet is offline   Reply With Quote
Old 09-17-2015, 06:40 AM   #416
Noob
Drives: AUDI 80
Since Ford sells itīs Stang now worldwide (and in spite of high fuel prices their V8 sells better (buyers have to wait 6months now!) than the I4 here in germany) you should not only look at the USA selling numbers now.
GM with chevy and Caddillac left the european market and sells only the Camaro, ATS,CTS and Corvette at some Opel dealers under "GM premium cars".
At the moment we have the IAA in Frankfurt and Fordīs Stang is a impressive eye catcher there ! No sign of a Camaro 2016....ah yes 1 they find somewhere beside in a "chevrolet cafe".
I searched at IAA for chevy or Camaro or corvette and found NOTHING.
I think itīs chevyīs fault when global selling numbers went bad.....
Noob is offline   Reply With Quote
Old 09-17-2015, 06:53 AM   #417
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Facts:
1) Ford is a company, Chevrolet is a nameplate within the company General Motors.
2) With the exception of "Pony Cars" (a small segment), GM was leading Ford in most segments at mid year. The one segment where Ford lead was helped by a new version of the Mustang. It remains to see how that will play out in 2016 with the introduction of a new Camaro by GM.
3) NO GERMAN car manufacturer is even on the radar, but I bet there were Audis, MBs and VWs at the IAA, so having a car on display at that show seems to be uncorrelated with global auto sales.
http://www.autonews.com/article/2015...ales-rivalries
Facts beat trolls every time.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-17-2015, 07:42 AM   #418
Cody6.2
Drives: 2012 Camaro 2SS
Not everyone wants a 20" wheel not to mention it isn't a performance advantage. Just like you don't need to spend extra for gearing with a Mustang as the transmission ratios are numerically higher.
Cody6.2 is offline   Reply With Quote
Old 09-17-2015, 08:01 AM   #419
shaffe
Drives: 21 Bronco
Yea I was reading too far into what you were saying.
I honestly think Ford is missing out by not offering the PP with the auto GTs. They offer it for the EB Auto, so beginning to wonder if they had some concerns with auto's reliability with the 5.0 on the track.
Think we should also note the SS really only gets additional coolers over what would be comparable in a base GT. Ford's PP adds a lot of equipment, so there was no way it would appeal to everyone and would drive cost up. In that sense we probably really wouldn't see any savings by offering the cooling package separate. 6 piston brakes are already optional, so what else are we considering was too much extra for the 1SS?
No reason for them to hold it close since the transmission is being co-developed with GM anyway. So GM will have the trans at the same time too. Now maybe they didn't want people to hold off buying one this year if the 10 speed was coming out next. That I could see.
The 6R80 is a very stout transmission. You could get the PP on one of the limited special edition that they only made 1964 off, so I am not sure why they didn't offer it as a option for regular GTs. Maybe they thought wrong and that only people who got the manual would see/enjoy the benefits of the PP.
This is just me and I think a few others share this view. Those of us that live in the mid west and states that get snow who might use these cars as DDs, all seasons are better from the factory than summer only. No need to buy a new set of wheels and tires for winter.
Originally Posted by GretchenGotGrowl View Post
Facts:
Fact: Ford is a brand. Ford Motor Company is the parent company. Ford Motor Company is compromised of Ford and Lincoln. Ford brand competes with the Chevrolet brand. Ford Motor Company competes with General Motors.
Old 09-17-2015, 08:09 AM   #420
GretchenGotGrowl
And the numbers in the link look at all of FMC vs all of GM instead of just FMC vs Chevy as the troll was trying to do.
