dave@hennessey
Old 11-15-2017, 11:36 AM   #1
Rostyle806
Rostyle806's Avatar
Drives: '13 2SS RS
1LE hub help
Does anyone know a current part number for rear 1LE hubs?
Dealership shows 3 different numbers 13589509, 23216847, 13580135
I’m putting a 1LE 3.91 diff into my ’13 2SS, along with 1LE axles (22806795, 22806796) figured I’d upgrade the hubs as well, just having trouble finding which part # that’s needed
Rostyle806 is offline   Reply With Quote
Old 11-15-2017, 12:17 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
You may do a search, i thought the 1LE hubs were the same as the ZL1 hubs.
HOJO is offline   Reply With Quote
Old 11-15-2017, 12:47 PM   #3
Rostyle806
Rostyle806's Avatar
Drives: '13 2SS RS
yah looked up both, just all the part numbers in past posts seem to be discontinued
Old 11-15-2017, 04:20 PM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
SS and 1LE same size..25954415 lists as ZL1..when I did my axle swap just left the SS one's in...figured replace when they fail, easy job..good luck!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 11-15-2017, 04:25 PM   #5
Rostyle806
Rostyle806's Avatar
Drives: '13 2SS RS
Ok great thanks
Old 11-16-2017, 01:55 AM   #6
Spurshot
Drives: 2014 2SS blue
I bought the 4415s.
Spurshot is offline   Reply With Quote
Old 11-16-2017, 04:38 PM   #7
Rostyle806
Rostyle806's Avatar
Drives: '13 2SS RS
Thanks, I’ve got some on the way
Old 03-24-2018, 10:19 PM   #8
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
What brand did you guys go with? ACDelco? Man those suckers aren't cheap!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 03-24-2018, 11:26 PM   #9
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
those the Z28 ones? 4415
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 03-28-2018, 08:17 AM   #10
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
ZL1/Z28 Hubs - 25954415 (ACDelco RW20-119)
http://www.camaro5.com/forums/showth...=434445&page=2
look at post # 28
I found new ones on ebay from rolling automotive for $50ea! heck of a deal
they seem to be sold out at the moment, contact them to see if they'll get some more in.
EDIT: pics and discussion here http://www.camaro5.com/forums/showpo...&postcount=150
1le, rear hubs, zl1
